08 acura tsx
mike08401
Member - Posts: 33
Posted: June 02, 2009 at 6:43 PM / IP Logged
I tried to install starter/alarm in my sister 08 acura tsx but i'm stuck because i'm really confused about factory DisArm and rearm wire the diagram just show only disarm also it stated in side driver door(FACTORY ALARM DISARM   WHITE (-)   @ DRIVERS DOOR MODULE IN DRIVERS DOOR ) so my question is : Do i have to find wire inside the door and connect it there or it should be connect some where in side car under dash... I've tried to trace the white wire with silver dot it go inside car but show no contact I really need help to find this wire
Many thanks
tommy...
Gold - Posts: 1,901
Posted: June 02, 2009 at 7:00 PM / IP Logged
yes...to my knowledge that is the only place to get it...There are units you can buy to control door locks/factory security.
M.E.C.P & First-Class
mike08401
Member - Posts: 33
Posted: June 02, 2009 at 8:22 PM / IP Logged
Hi tommy!
What's part you are talking about? Do you have any sugestion how to run this wire from/to that port???
tommy...
Gold - Posts: 1,901
Posted: June 02, 2009 at 9:35 PM / IP Logged
08 acura tsx - Last Post -- posted image. XK01 - Programmable Platform# 01: Door Lock & Alarm Interface
Firmware: HODL4 2.00
tommy...
Gold - Posts: 1,901
Posted: June 02, 2009 at 9:39 PM / IP Logged
  CANMAX400 Multi Function Programmable Vehicle Interface
Firmware: 400.HONDA4 0.09
Combination of Immobilizer Bypass and Data Bus Door Lock Control
cliffordtech82
Posted: June 03, 2009 at 10:21 PM / IP Logged
Try going into drivers door and you will find a white and red for your arm and a white for your disarm. Goodluck
Moderator - Posts: 12,488
Posted: June 04, 2009 at 8:57 AM / IP Logged
You can use a data module to control the alarm features as well as bypass the OEM immobilizer. It's way easier and no need to run wires into the door. The door also has a molex which is a tremendous PITA for anyone to have to run wires through it.
tommy...
Gold - Posts: 1,901
Posted: June 04, 2009 at 9:00 AM / IP Logged
Ditto ...If it is your first adventure w/ molex...By-pass will work fine...Pretty easy install...
mike08401
Member - Posts: 33
Posted: June 04, 2009 at 7:40 PM / IP Logged
Thank You all for repplied after some research and sugestion I think I will go with Idatalink module which control door and immob. too
Once again The12volt is the #1 place to get help
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
