OK on with the install!!!
We will start with the door wiring. Since I have a 0 option car I ony had 2 small (20ga?) wires going to the door as seen here.
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Door-wiring.jpg[/IMG]
I took that out and was greeted with this.
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Clip-Full.jpg[/IMG]
I then decided that I could just taket that out since I dont need it for anything now, so I got this
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Clip-Empty.jpg[/IMG]
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Looktrhrough.jpg[/IMG]
And here is the stock wiring that came out
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Stockwire.jpg[/IMG]
I then ran my new stinger 14ga wire through the stock gromets and threw in the new speakers (JL Audio C2-650x)
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Speaker.jpg[/IMG]
Moving on to the trunk I was changing the battery to a new Kinetic KHC800 battery, adding a ground, and redoing the amp wiring.
Here you can see the battery mocked up with the pices I had to make inorder to hold the battery with the factory tie down.
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Battery1.jpg[/IMG]
Here is the battery without the top piece (The wires were from a battery tender)
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Battery.jpg[/IMG]
Here is the bottom piece to hold the battery from side to side and front to back movement.
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Batterytray.jpg[/IMG]
and painted
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Batterytray-Painted.jpg[/IMG]
Here is the new Stinger distrobution block that has 2 seprate fuses because each amp needs a different rating. It has 4ga in and 2 8ga out.
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Distro2.jpg[/IMG]
Here is new 4ga ground lug I added (the paint was ground off underneith it)
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Ground-Lug.jpg[/IMG]
Here is a shot of all the power side of things
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Power.jpg[/IMG]
Here is the ground side
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Grounds.jpg[/IMG]
And over all
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Wiring.jpg[/IMG]
Next came running the new RCA's adding my Sirius box, and cleaning up some of my wiring behind the headunit. I didnt get many pics of all of this but you can see the sirius box on the bottom left and the strat of cleaning up the wiring.
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Center-Console.jpg[/IMG]
Now the best part, installing the new amp!! Here is just seeing how it will look (you can see some of the mess in this pic)
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Interior.jpg[/IMG]
Installed
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Interior-Amp.jpg[/IMG]
And both together
[IMG]https://i166.photobucket.com/albums/u95/BrokeEF/System/Amps.jpg[/IMG]
Well thats all the pics I took, I was to busy working to get very many. Over all I am VERY happy with it, sounds a lot better and is a lot louder! Sorry for the long post, but Im excited about my stereo.
Sean
