renault megane 2004
igni
Member - Posts: 11
Posted: July 20, 2009 at 9:00 AM / IP Logged
Hihi.
Anybody have wiring diagram for renault megan 04 please?
Brg
Ingi
Reykjavík
Iceland
ingi
igni
Member - Posts: 11
Posted: July 20, 2009 at 11:17 AM / IP Logged
Sorry!!
I am instaling a fortin security system.
ingi
Posted: July 20, 2009 at 11:42 AM / IP Logged
Is this the newer shape with the credit card key slot in the centre? If so behind the glovebox (right hand drive is a processor box with ign start etc. Your best bet would be to contact Cobra in Italy or France,  they supply the dealer fits and might might be able to help.
igni
Member - Posts: 11
Posted: July 20, 2009 at 12:00 PM / IP Logged
Hihi
This is the new body with the card key.
Left hand drive couse icelanders drive on the wrong side of the road.
I found all the wires in the BCU under the steering wheel
This car isn't as bad as i thougt.
Thanks for the advise.
Ingi.
ingi
Posted: July 20, 2009 at 5:10 PM / IP Logged
And y6ou don't mind snow and ice, here it shuts down the bloody country! Glad you sorted it, I HATE French cars.....till I get an Italian.
kola7126
Copper - Posts: 93
Posted: July 22, 2009 at 5:37 AM / IP Logged
Hi! I Get This Car.
SUPPLY
Positive
Negative
�� 2,5 mm2. RED-PINK wire, pos. 4, 4-way BLACk connector signed “PP1”,
connected to the black unit fixed on the steering column left side.
�� To a bolt of the metallic frame.
FUNCTION AND CONNECTION
PROCEDURE
WIRE COLOUR OF THE
VEHICLE
WIRE POSITION
TURN SIGNALS:
ORANGE 0,75 mm2.
BEIGE 0,75 mm2.
Connector: GREY 12-way signed “PP3”,
Position: Nr. 4 and 5.
POSITIVE UNDER KEY:
YELLOW-BROWN 0,75 mm2.
Connector: WHITE 4-way connected to
the brake pedal button.
Position: Nr. 2.
1ST ENGINE IMMOBILISER: (Starter motor).
PINK-WHITE 0,5 mm2.
Connector: BLACK 4-way connected to
the START push-button placed under
the car-radio pre-equipment.
2ND ENGINE IMMOBILISER: (diesel vehicle).
RED 0,75 mm2.
"PPM2 GREY" connected in front of the
engine compartment fuse box, placed at
the back of the driver side head-light.
Position: Nr. 3.
CDL: diagram Nr. 2. Negative common.
OPEN and CLOSE:
GREEN-WHITE 0,5 mm2.
(Connect to this wire the RED-GREY
and YELLOW-GREY wires of Gemini
alarm).
Connector: WHITE 40-way signed “PE1”,
Position: Nr. 6.
ELECTRICAL WINDOW WINDER: Version
without “MAGIC” function. Use a Gemini 2344
module.
Front:
a. + <"Arial" >�� LH: BLACK-WHITE
- <"Arial" >�� LH: BLACK-WHITE
Ref. GREY
b. + <"Arial" >�� RH: GREY-WHITE
- <"Arial" >�� RH: BROWN-WHITE
All sized 1,5 mm2.
a. Connector: LIGHT BLUE 12-way
connected to the push-button control,
inside the driver side door.
Position: Nr. A4 and B5.
b. Wiring harness coming from the
Posted: July 22, 2009 at 12:40 PM / IP Logged
Kola thanks, I've been trying to avoid doing one, if I have to this will help.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
