need wiring info, 2002 ferrari f360
stevetolentino
Member - Posts: 38
Posted: July 23, 2009 at 3:11 PM / IP Logged
I have a 2002 Ferrari F360, just putting a tracking system in and need 12v wiring info.  colors and locations of these circuits to hook up.  Please help.
Thanks in advance.
chev104275
Gold - Posts: 1,428
Posted: July 23, 2009 at 8:07 PM / IP Logged
    2002 FERRARI F360 SPIDER 2DR CONVERTIBLE
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION HARNESS
Ignition 1 YELLOW/WHITE (+) IGNITION HARNESS
Starter 1 YELLOW (+) IGNITION HARNESS
All Door Trigger WHITE (-) AT DRIVERS DOOR PIN SWITCH
Parking Lights GREEN (+) SWITCH HARNESS
Remote Start
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript TRANSPONDER
Doorlocks/Windows
Power Unlock WHITE (+) AT SWITCH IN CONSOLE
PowerLock RED (+) AT SWITCH IN CONSOLE
   i cant verify any of this info as ive never done or even been inside one good luck
Posted: July 24, 2009 at 1:07 AM / IP Logged
Look in the rear section, see if there's a fuse box there, locate 12v+, 12v+ ign and a good ground, pull rear light and mount antennae there, if mid-engined, go to front, if fibre glass body, mount antennae inside, if metal, see above.
stevetolentino
Member - Posts: 38
Posted: July 24, 2009 at 9:08 PM / IP Logged
Thank you very much Chev104, I appreciate it very much.
Steve
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
