Bypass Factory Amp w/pics, 2003 Hyundai Tiburon
swaggerer
Posted: July 30, 2009 at 2:19 AM / IP Logged
I have a 2003 Hyundai Tiburon GT with the Infinity Sound System. Originally, my speakers had no sound coming out of them. I thought it was because of a faulty stock head unit. Then, I installed my aftermarked Pioneer AVH-P3100DVD head unit--still no sound. Now, there are two things that could be faulty: either the factory amp or a blown fuse or something. Anyways, I'm trying to bypass the factory amp and see if that fixes the problem. I've removed my rear seats and side panel and removed the factory amp.
Where do I go from here? I've heard you have to cut and splice the wires but I'm not sure. I don't want to run wires from the head unit to each speaker as that would be a PITA. I know there's an easier way to do it since all the wires are connected to the stock amp. Detailed instructions would be nice since I'm kind of an audio noob ;).
Wiring Diagram (click on the first link [#1]): http://www.crutchfield.com/App/Support/KnowledgeBase.aspx?ifs=hyundai+tiburon
Pics:
Bypass Factory Amp w/pics, 2003 Hyundai Tiburon -- posted image.
haemphyst
Platinum - Posts: 5,054
Posted: July 30, 2009 at 8:53 AM / IP Logged
Seems you are SOL for the bypass harness... Even Metra doesn't have one.
Time to get your meter out, and start poking into plugs! Have you checked for voltage (power) at the amplifier's input? Here's where I would start looking.
swaggerer
Posted: July 30, 2009 at 11:50 AM / IP Logged
^Well, even though there is no harness, that doesn't mean it can't be done...right? Here's my idea:
^ Yes. But, even with the old head unit, the speakers wouldn't work.
To bypass the amp, this is my understanding of what to do: (please correct me if I'm wrong)
1. Cut each of the white connector ends off of the wire sets in order to gain access to the wires.
2. Following the wiring diagram below, splice the input wires with their corresponding output wires. The inputs are colored the same as their corresponding outputs. Since I have front tweeters, won't I just twist the output of those together with the output of the front door speakers and then splice those with the front input? (for example: there is only one right front input but two right front outputs; one for tweeter and one for door speaker.)
OUTPUT:
INPUT:
memfus_boi
Copper - Posts: 148
Posted: August 07, 2009 at 11:19 PM / IP Logged
that looks about right but make the wires not in use are not bare. ex.... remote, power, and etc. leave them plugged in or tape the unused wires and enjoy!
If I'm to loud, then you're too old!!!
whiterob
Copper - Posts: 351
Posted: August 08, 2009 at 1:18 AM / IP Logged
Before you go and start cutting up the factory wiring why don't you confirm that it is the stock amp first? Do you have a DMM like haemphyst said?
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
