no sound from subs
curtislex
Posted: August 08, 2009 at 10:45 PM / IP Logged
i am running a quantum audio 3000watt class d amp to two rockford t1 15s with a pioneer avic-z1 deck. my system worked fine in my tahoe then i traded my tahoe in for a 2000 monte and now i cnat get any sound from my subs. the amp powers on and doesnt go into protect. i used a multimeter to check my power voltage and got a little over 12 volts from the power and my remote was getting 11.5 volts. i guess it was getting 11.5 because i checked with the car turned on but not started. i tried to check my rcas with the multimeter but it wasnt making sense to me. i touched the positive to the prong and the neg to the outer shell and soon as i touched it the volts jumped to .20 but then slowly went down to .03. is this correct or not. also what is the correct procedure for testing the rcas because i have read on many forums many ways of doing it. i know the prong is pos and the shell is neg but when i check them should i check one side of the rca at a time or do i use one side for the pos and the other for the neg?
also everything is the exact same thing that i removed from my tahoe. the amp is only about 2 weeks old i bought it a couple of days before i traded my tahoe in. the only difference is the radio wirng harness. i had to use the gmos-01 metra harness so i could retain my door chimes and all that.
stevdart
Platinum - Posts: 5,816
Posted: August 09, 2009 at 8:23 AM / IP Logged
You could just be in too much of a hurry.  Take your time, check all connections and controls.
tommy...
Gold - Posts: 1,901
Posted: August 09, 2009 at 8:38 AM / IP Logged
Does that radio have an option to turn sub off/on...? Might be as simple as turning the sub feature ON...?
M.E.C.P & First-Class
yimke
Copper - Posts: 417
Posted: August 09, 2009 at 9:21 AM / IP Logged
Positive to prong and negative to the outer shell. It should increase AC volts as the volume is increased. If no voltage check connections behind deck. If those are good move to step 2.
Also check the sub on/off feature. If it is on check continuity between the prong/shield of the RCA to see if they are pinched together. And then check for continuity to ground on each part of the RCA (prong, then outer) It could be a screw through the rca causing the signal to ground out.
And finally check the AC voltage coming off the amp.
It's probably one of the first 2 things though.
curtislex
Posted: August 11, 2009 at 4:40 PM / IP Logged
the sun on/off feature is turned on. i tried the rcas in the rear output and the front output and the sub output still nothing. i had this same problem when i tried to install a system in a 2005 impala. i dont kno or see y it would affect the amp and subs but in that car we also had to use the gmos-01 harness from metra. when i tested my remote wire with the multimeter it was only getting 11.5 volts but as far as i kno that shouldnt be a problem.
Platinum - Posts: 13,670
Posted: August 11, 2009 at 4:51 PM / IP Logged
Is there a Master/Slave switch on the amp?  If so make sure it is in the Master position.
curtislex
Posted: August 13, 2009 at 9:17 PM / IP Logged
i brought my old 12s out of the bassment and hooked them up and they worked so i dont understand y my 15s arent. i dont think they are blown and if they are shouldnt they make some sort of sound regardless. i can push on them and they move in and out freely so i know the voicecoils arent fried. i dont see y they wouldnt work they worked fine when i took them out of my tahoe, unfortunately the warranty of my t1's ran out 2 months ago and that sucks seeing as how i paid $450 a piece for them. any ideas on what the problem could beor are the subs just completely gone.
Posted: August 13, 2009 at 9:36 PM / IP Logged
Are they dual voice coil?  Did you take them out of the box and make sure the connections are good on the back of the terminal cups.
tommy...
Gold - Posts: 1,901
Posted: August 14, 2009 at 9:03 AM / IP Logged
take a battery and put the wires coming from 15's to the + and - of battery...Did the speakers move...? try again with the battery, but this time touch it to the tinsel leads...!(wires from terminal of sub that run into speaker.)
yimke
Copper - Posts: 417
Posted: August 14, 2009 at 11:33 PM / IP Logged
What ohm wiring setup are you running this at out of curiosity.
And measure the ohm resistance of each coil since you have a multi-meter. If they don't measure 4 ohms, that will be your issue.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
