dodge dakota 2009
f29966
Member - Posts: 36
Posted: August 17, 2009 at 10:33 PM / IP Logged
i'm looking for all the wiring diagram to do remote start & security , i can't find it , please help , thanks
Platinum - Posts: 13,671
Posted: August 18, 2009 at 6:08 PM / IP Logged
WIRECOLORPOLARITYLOCATION dodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.BatteryLIGHT BLUE/RED(+)IGNITION SWITCH HARNESS
dodge dakota 2009 - Last Post -- posted image.Ignition 1PINK/GRAY(+)IGNITION SWITCH HARNESS
dodge dakota 2009 - Last Post -- posted image.Accessory 1VIOLET/BROWN(-)IGNITION SWITCH HARNESSdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Starter 1YELLOW/GRAY(+)AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDERdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Starter 2VIOLET/BROWN(-)IGNITION SWITCH HARNESSdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Anti-Theft TypeDAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
dodge dakota 2009 - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
dodge dakota 2009 - Last Post -- posted image.Key SenseVIOLET/BROWN(-)IGNITION SWITCH HARNESSdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Speed SenseYELLOW/PINK(AC)AT PCM MODULE UNDER HOOD ON PASSENGER FENDERdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Parking LightsPINK/RED(-)AT VEHICLE LIGHT SWITCH HARNESSdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Brake LightsWHITE/ LIGHT BLUE(+)AT SWITCH ABOVE PEDAL
dodge dakota 2009 - Last Post -- posted image.Reverse LightsWHITE/ LIGHT GREEN(+)AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
dodge dakota 2009 - Last Post -- posted image.HornDARK GREEN/ VIOLET(-)IN HARNESS AT STEERING COLUMN
Also read the following post for the resistor information required for this vehicle.  https://www.the12volt.com/installbay/forum_posts.asp~TID~115738~get~last#562535
Posted: August 18, 2009 at 6:10 PM / IP Logged
dodge dakota 2009 - Last Post -- posted image.All Door TriggerYELLOW/ORANGE(+)IN HARNESS AT VEHICLE GAUGE CLUSTERdodge dakota 2009 - Last Post -- posted image.
dodge dakota 2009 - Last Post -- posted image.Domelight SuperYELLOW/ORANGE(+)IN HARNESS AT VEHICLE GAUGE CLUSTER
dodge dakota 2009 - Last Post -- posted image.LF LatchVIOLET(-)IN HARNESS AT VEHICLE GAUGE CLUSTER
dodge dakota 2009 - Last Post -- posted image.RF LatchVIOLET/WHITE(-)IN HARNESS AT VEHICLE GAUGE CLUSTER
dodge dakota 2009 - Last Post -- posted image.LR LatchVIOLET/GRAY(-)IN HARNESS AT VEHICLE GAUGE CLUSTER
dodge dakota 2009 - Last Post -- posted image.RR LatchVIOLET / YELLOW(-)IN HARNESS AT VEHICLE GAUGE CLUSTER
dodge dakota 2009 - Last Post -- posted image.Hood TriggerVIOLET/LIGHT BLUE(-)AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
dodge dakota 2009 - Last Post -- posted image.Alarm Disarmdodge dakota 2009 - Last Post -- posted image.
Info on this post is for security.  Prior post is Remote Start info.
Posted: August 18, 2009 at 6:21 PM / IP Logged
USE A 1.1K OHM RESISTOR FOR PARKING LIGHTS, MUST ISOLATE FROM SWITCH WITH A RELAY    Let us know if you need help with that.
f29966
Member - Posts: 36
Posted: August 19, 2009 at 11:23 PM / IP Logged
thanks alot for the information
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
