Delta & Proximity Sensor
enforcerviper
Member - Posts: 26
Posted: March 28, 2003 at 4:12 PM / IP Logged
Right now I have a Delta DA Combo remote start and alarm.  The unit is pretty in expensive, but it works fine.  Right now I have a dual stage shock sensor that is hooked up.  Is there any proximity sensor that will work with this unit?
here is a pic of the unit, since it's probably a rebranded something?
Delta  & Proximity Sensor -- posted image.\
Thanks for all your help.
enforcerviper
Member - Posts: 26
Posted: March 28, 2003 at 4:17 PM / IP Logged
Sorry, actually my unit is the older version, but the same hookup & brain.  Here is a pic
enforcerviper
Member - Posts: 26
Posted: March 28, 2003 at 6:12 PM / IP Logged
oh yeah, the wires coming out of my shock sensor input are blue, red, white and black.
enforcerviper
Member - Posts: 26
Posted: April 02, 2003 at 6:13 PM / IP Logged
nobody?
CruisinS&S
Copper - Posts: 225
Posted: April 02, 2003 at 7:17 PM / IP Logged
you should be able to hook up any prox. sensor, you should be able to hook it up to the blue and white wires off the Delta sensor. Test which wires(blue or white)do what. They both should test neg. - one when it is tripped on the warn away and one when the sensor is actually triggered
Hope this helps, by the way DEI makes a good prox. sensor
Cruisin Security And Sounds
enforcerviper
Member - Posts: 26
Posted: April 02, 2003 at 8:25 PM / IP Logged
Thanks, I assume I have to use diodes to separate to the two circuits? From some reading on this board I have also come to the conclusion I should use ground and power from a different source (usually brain) as well?
CruisinS&S
Copper - Posts: 225
Posted: April 02, 2003 at 10:45 PM / IP Logged
I don't think you will need diodes but use them in case and defenitly get your power and ground supply from a different source than the shock sensor. The units wires would work without a problem. That should do it!!
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
