passive xover
dohckiller808
Member - Posts: 28
Posted: September 08, 2009 at 4:29 AM / IP Logged
if you have a passive crossover that cuts 4.5k to 20k to a 4 ohm load, if i use an 8 ohm tweeter where will the crossover cut off at?
150SPL musical in a civic coupe
DYohn
Moderator - Posts: 10,741
Posted: September 08, 2009 at 8:34 AM / IP Logged
Double the impedance = cut the crossover knee in half.  So 2.250KHz.  And realize that crossovers do not "cut off."  The Xover frequency is simply the point where attenuation begins (or the -3db point, depending on the design.)
passive xover -- posted image.
https://www.the12volt.com/caraudio/cross.asp
haemphyst
Platinum - Posts: 5,054
Posted: September 08, 2009 at 9:04 AM / IP Logged
dohckiller808... I am also interested in your build, based on your sigline...
Care to post your system info?
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
