98 explorer radio wiring problems
thatguyandrew92
Posted: September 20, 2009 at 4:14 PM / IP Logged
I have a 98 Ford Explorer XLT and I cant find the the correct wire diagram for my radio in my truck. I tried a converter from Crutchfield but it didnt work. PLEASE HELP! :D
Here are my wires
Yellow/Black
Black (2 of them)
Brown
RED / White
RED / Black
ORANGE / White
Light Blue/Black
light Green
WHITE/ Purple
Light Blue
Yellow
Light GREEN/ Purple
BLACK/ Green
Blue 98 explorer radio wiring problems -- posted image.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 20, 2009 at 10:25 PM / IP Logged
Constant 12V+Light Green
Switched 12V+Yellow/Black
GroundBlack
IlluminationLight Blue/Red
Dimmern/a
Antenna TriggerORANGE / Blue
AntennaRight Front
Front Speakers5" x 7" Doors
Left Front (+)ORANGE / Light Green
Left Front (-)Light Blue/White
Right Front (+)Dark GREEN/ Orange
Right Front (-)WHITE/ Light Green
Rear Speakers5" x 7" Rear Door
Left Rear (+)Gray/Light Blue
Left Rear (-)Tan / YELLOW
Right Rear (+)ORANGE / Red
Right Rear (-)BROWN / Pink
tommy...
Gold - Posts: 1,901
Posted: September 20, 2009 at 11:59 PM / IP Logged
Is there an antenna wire behind the radio...? If not i think you have to bypass the amp located in RR of vehicle...Or run new leads from deck to speaker...Or an amp intergration harness...Is there a Kinda long grey plug...then a more square green or black plug... ?
Metra Electronics Corp. 70-5517
Factory amplifier integration harness
M.E.C.P & First-Class
thatguyandrew92
Posted: September 21, 2009 at 12:52 PM / IP Logged
There is an antenna wire. There is a long grey plug and a square black one.
soundnsecurity
Gold - Posts: 2,711
Posted: September 21, 2009 at 1:00 PM / IP Logged
i think thats only on the explorer sport edition that you have to take apart the rear quarter panel to make the antenna work.
thatguyandrew92
Posted: September 26, 2009 at 12:33 PM / IP Logged
Anyone?
obxtint
Member - Posts: 6
Posted: September 26, 2009 at 3:12 PM / IP Logged
Was it a converteror wire harness from Crutchfield?
What didn't work on it? Did the radio power up with no output?
That's Why we've got to take the power back! RATM
KarTuneMan
Posted: September 27, 2009 at 1:03 AM / IP Logged
You can get to all of the amp outputs in the pass. running board area.
Should be the same colors as I listed in my first post!
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
