viper 5701, error, pairing instructions?
rutcgr18
Member - Posts: 45
Posted: September 24, 2009 at 9:28 PM / IP Logged
Got a new 2 way remote.  Prgramed it.  Seem to work fine.  Now i hit the lock or unlock button and it unlocks and locks but also gives me a error sound. I have del the remote from the unit i need to add it again and see if that fixes it.  Who has the pariing instuctions?.  THoughts on the other problem??
kgerry
Platinum - Posts: 3,455
Posted: September 25, 2009 at 9:44 AM / IP Logged
unplug the 12? pin harness that powers the brain for a minute or so and plug it back in.... these units had issues with the out-of-range notification circuit, that was remedied by "rebooting" the brain.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
rutcgr18
Member - Posts: 45
Posted: September 25, 2009 at 10:33 AM / IP Logged
thanks does any one have the steps to add a remote??
kgerry
Posted: September 25, 2009 at 2:07 PM / IP Logged
i uploaded the programming guide
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
rutcgr18
Member - Posts: 45
Posted: September 26, 2009 at 7:46 PM / IP Logged
I have add the remote still having problem.  I have unplugged my brain for 3 hours and it is still doing it.  Is there a firmware upgrade for these things.  It really anyoing.  I am thinking about just buying a new system.  Not happy with DEI on this one.
rutcgr18
Member - Posts: 45
Posted: September 26, 2009 at 7:55 PM / IP Logged
I found this info any one have any incite on this??
Directed will be shipping out new brians in the next few months with a firmware update that resolves this issue completely. Depending on where it was purchased, I would believe most retailers will do a swap for you when those are shipped and become available. In the meantime there is a fix. Place a 10,000 ohm resistor in series with the blue wire on the antenna lead as close to the brain as possible. Hope this helps!
rutcgr18
Member - Posts: 45
Posted: September 29, 2009 at 4:50 PM / IP Logged
Bump no one can help on this one.  Can i update the firmware on this thing?
mike
xtremej
Gold - Posts: 1,440
Posted: September 29, 2009 at 4:55 PM / IP Logged
no you cannot, just add the 10k ohm resistor to the antenna lead as described.
rutcgr18
Member - Posts: 45
Posted: September 29, 2009 at 5:15 PM / IP Logged
what does that acutally do?
vipersport328
Member - Posts: 8
Posted: January 18, 2010 at 8:37 PM / IP Logged
I have the same problem with my 5701 two way remote. Unplugged the brain and still have the same problem. Has anyone added the 10k ohm resistor in series? Just seeing if that works. Thanks
Pete
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
