00 astrovan and viper 550esp
Nuffstylez
Copper - Posts: 58
Posted: October 20, 2009 at 11:12 PM / IP Logged
My friend is having trouble with his van.  The alarm was working perfectly all the time and just stopped one day.  We changed the battery in the transmitter but that didnt help.  The alarm doesnt arm or disarm and the remote start doesnt work.  The transmitter doesnt work for it either.  The alarm was set for active so it won't arm on its own.  I took a look at the wiring and everything looks good.  All fuses are good.  Here's the weird thing.  I figured that maybe the remote needs to be relearned so I tried programming it but that doesnt work.  The siren doesn't chirp and the led doesn't blink to tell me that I am in the programming mode. It's like the alarm is dead.  I checked all power and grounds and all are good.  What else could it be? One more thing, When I disconnect the main harness from the alarm and reconnect it back the car will remote start on its own with no input from the alarm, is that normal???
Moderator - Posts: 12,488
Posted: October 21, 2009 at 8:12 AM / IP Logged
Make & model alarm system please.
Nuffstylez
Copper - Posts: 58
Posted: October 21, 2009 at 1:03 PM / IP Logged
hey sorry, I had it in the title.  I should of put it in the body too.  The alarm is a Viper 550esp and the van is a 2000 Chevy AstroVan
Posted: October 21, 2009 at 5:35 PM / IP Logged
Check to see if the antenna was damaged or unplugged. Also check to see if the system is in valet mode.
Nuffstylez
Copper - Posts: 58
Posted: October 22, 2009 at 6:40 PM / IP Logged
Hi, the alarm doesn't have any external antenna.  Also the alarm isn't in valet mode
Nuffstylez
Copper - Posts: 58
Posted: October 24, 2009 at 8:17 PM / IP Logged
Hey, thanks for all your help Velocity Motors.  I got it to work.  It turned out to be a bad remote transmitter.  And there was an external antenna. It was hidden for some strange reason.  thanks again
Posted: October 25, 2009 at 9:49 AM / IP Logged
No problemo
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
