2007 chrysler aspen wiring
Msp541
Copper - Posts: 52
Posted: October 31, 2009 at 5:35 PM / IP Logged
Hi All;
I am looking to find the wiring for the 2007 Chrysler Aspen to hook up the (12Volts, Ignition #1, and the Accessory wire) I was looking where it says in the wiring sheet the Ignition harness and cannot find those wires in there, is there another spot where these wires can be found?
Thanks!2007 chrysler aspen wiring - Last Post -- posted image.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 31, 2009 at 9:03 PM / IP Logged
I've only done Durangos, and not an Aspen, but there should be a small 4-wire plug just barely visible around the bottom edge of the steering column shroud.
You might choose to take the shroud off for easier access, but I think if you just unplug it, you'll have enough slack to make your connections.
You can probably find the constant and ignition wires in the steering column harness if you look around enough, but the only place you'll be able to get the PURPLE / brown multiplex/acccessory/starter wire is right there at that plug, because from there it runs back deeper up into the column rather than down.
