2007 silverado cruise control wiring?
rasjad
Posted: November 04, 2009 at 8:53 AM / IP Logged
New to the forum - what a great service.
My question - does anyone know the wiring for the steering wheel mounted cruise control? ie; How can I tap into the wiring harness & what are the wire colors?
I have the new style body, 2500HD truck.
sparkie
Platinum - Posts: 2,061
Posted: November 04, 2009 at 8:13 PM / IP Logged
What are you trying to do? Add a cruise or use the existing cruise control switches for something else? If you want to add factory cruise control, you must get it done at a GM dealer.
sparky
rasjad
Posted: November 04, 2009 at 9:12 PM / IP Logged
Actually I want to do the second - use the existing switches for something else. I want to wire the CC "cancel" button as a security "kill switch" - ie; you have to be pressing it while you turn the ignition to engage the starter - otherwise - no start. I'm willing to sacrifice the "cancel" button as it's just as easy to turn CC off, then back on as it is to "cancel" then back on.
sparkie
Posted: November 11, 2009 at 5:31 PM / IP Logged
The Gray wire in the first connector (green)of the BCM is the cruise signal wire. The cruise uses a resistor ladder circuit to control the cruise. That wire also handles all the other cruise functions. Adding resistance to this circuit will eliminate your cruise.
sparky
rasjad
Posted: November 12, 2009 at 10:07 PM / IP Logged
Thanks for the info
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
