2008 ram 2500 mega cab
ks audio
Member - Posts: 25
Posted: November 06, 2009 at 11:11 AM / IP Logged
I am hooking up a back up cam does any on know where the revers wire is.
ksaudio
spmpdr
Copper - Posts: 456
Posted: November 06, 2009 at 12:08 PM / IP Logged
     Battery          LIGHT BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK/WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 2          PINK/GREEN          (+)          IGNITION SWITCH HARNESS
     Accessory 1          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
     Starter 1          YELLOWGRAY          (+)          AT MODULE UNDER HOOD
     Starter 2          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
     Tachometer          DARK BLUE/GRAY          (AC)          AT PCM MODULE ON PASSENGER SIDE FIREWALL
     Speed Sense          DARK GREEN/ BROWN          (AC)          AT PCM MODULE ON PASSENGER SIDE FIREWALL
     Parking Lights          WHITE/ LIGHT GREEN          (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          WHITE/ TAN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ LIGHT GREEN          (+)          IN HARNESS UNDER HOOD ON DRIVER FENDER
     Horn          DARK GREEN/ VIOLET          (-)          IN HARNESS AT STEERING COLUMN
     Databus          WHITE/ ORANGE          (DATA)          IN HARNESS AT STEERING COLUMN
there you go
-A vision without a plan is just a hallucination-
ks audio
Member - Posts: 25
Posted: November 06, 2009 at 1:30 PM / IP Logged
thanks will this work for self start to or do I need a bypass box for the key?
ksaudio
spmpdr
Copper - Posts: 456
Posted: November 06, 2009 at 2:52 PM / IP Logged
I got that wire diagram from the remote start section in the vehicle wiring forum on this site under 2008 dodge ram 2500 you might check that out on your own
ks audio
Member - Posts: 25
Posted: November 06, 2009 at 3:03 PM / IP Logged
cool thanks for your help
ksaudio
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
