wiring subwoofers
1968pontiac
Posted: November 12, 2009 at 4:53 PM / IP Logged
i need to know how to wire 8 4ohm dvc subwoofers
DYohn
Moderator - Posts: 10,741
Posted: November 12, 2009 at 4:59 PM / IP Logged
What is your desired final impedance?
1968pontiac
Posted: November 12, 2009 at 5:02 PM / IP Logged
its going on a 2 load stable
DYohn
Posted: November 12, 2009 at 5:10 PM / IP Logged
Do this twice and connect the two sets in parallel.  Your net load will be 4-ohms.  There is no good way to get to 2-ohms net with your configuration.
wiring subwoofers - Last Post -- posted image.
1968pontiac
Posted: November 12, 2009 at 5:17 PM / IP Logged
this what i have 8 4ohm subs hooking to a bd3000 how to hook it to get the max go the amp
daniel gt1
Copper - Posts: 55
Posted: November 12, 2009 at 7:23 PM / IP Logged
try this link :
http://www.rockfordfosgate.com/rftech/woofer_wizard_form.asp?p_series_submitted=true&p_search_type=series&woofer_qty=8&woofer_imp=1
see if this helps you
Platinum - Posts: 13,671
Posted: November 12, 2009 at 7:35 PM / IP Logged
According to Power Acoustik, that amp is 1 ohm stable.  I do not know if I would attempt to run it into 1 ohm.  But if you wish to get the maximum amount of power from the amp, you can do the following twice.  Then connect both positive wires to the positive terminal of the amp, and connect both negative wires to the negative terminal of the amp.
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Posted: November 12, 2009 at 7:40 PM / IP Logged
Once you asked about DVC drivers, the next time you you said nothing about DVC.  Which is it?
1968pontiac
Posted: November 16, 2009 at 12:22 PM / IP Logged
sorry about that they or dvc will i get the max out of the amp when i hook it up that way
Posted: November 17, 2009 at 5:58 AM / IP Logged
According to the Manufacturer that amp will run into a 1 ohm load.  And yes that is how you would have to wire it in order to achieve that load.  And yes it will make it's max power into that load.  If it were me, I would at least try it into the 4 ohm load that DYohn suggested.  Then if that is not loud enough for you maybe you could try the 1 ohm configuration.  The amp will last much longer into the 4 ohm load.  The cost to repair that amp after the 1 ohm load takes it out is over 200 dollars. I think I saw them selling that amp for around 300 dollars.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
