kenwood stereo in 1993 toyota pickup
couch change
Member - Posts: 6
Posted: November 22, 2009 at 11:09 PM / IP Logged
Howdy....Was wondering if I could get some help. I'm a confused puppy ATM. Here's a pic of the 3 wires left I have coming from the new stereo: kenwood stereo in 1993 toyota pickup - Last Post -- posted image.
Now here's the remaining wires coming from the trucks wiring harness (taken from this site)
Constant 12V+     Blue / YELLOW
Switched 12V+      Gray
Ground      Brown
Illumination      Green
I don't know what goes to what and to compound that the stereo manual says the ground wire should go to the chassis yet according to toyota the brown wire is the ground..... Also there is one more wire, a red&black striped one which is separate from the main harness yet was connected to the old stereo. Any help is appreciated.
Platinum - Posts: 13,673
Posted: November 23, 2009 at 5:09 AM / IP Logged
New Radio, Constant = Yellow  Switched = Red   Ground = black  Illumination (If it has one) = ORANGE / White
Grounding the radio to the wire suggested on this site should work fine.  it will make for a cleaner loking install.  If you are having problems with engine noise, you may try grounding it to the chassis instead.
couch change
Member - Posts: 6
Posted: November 24, 2009 at 11:50 AM / IP Logged
Thanks for the help. Got it installed and works great. kenwood stereo in 1993 toyota pickup - Last Post -- posted image.
boxhead78
Copper - Posts: 84
Posted: November 25, 2009 at 9:16 PM / IP Logged
yellow to blu/yel,red to gray,and black to brown
boxead78
