96 lumina
ShaunD912
Copper - Posts: 140
Posted: April 04, 2003 at 12:23 PM / IP Logged
I'm installing an add on remote start unit to a 96 lumina. Could anybody give me a suggestion as to where to mount a hood pin switch? I haven't found anywhere that would work so far. Thanks.
ShaunD912
Copper - Posts: 140
Posted: April 06, 2003 at 10:25 AM / IP Logged
Ok, well I got the pin switch, but there's something weird about this module or something. It has a pink wire that activates the remote start when grounded. I touched the pink wire to ground and the car started perfectly. The car has a blue wire that shows positive when the lock button is pressed on the keyless entry. I used a relay to send ground to the pink wire using this blue wire like this:
85 and 87 = ground
86 = blue wire
30 = pink wire
The relay clicks and I tested the pink wire at the remote start brain and it's getting ground when the lock button is pressed. But the car won't start. I can take the pink wire off the relay and ground it and it will start but not using the relay. I can't figure it out. Any suggestions please?
draasch
Gold - Posts: 2,172
Posted: April 06, 2003 at 12:02 PM / IP Logged
what brand are you installing??????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
ShaunD912
Copper - Posts: 140
Posted: April 06, 2003 at 9:04 PM / IP Logged
Omega Electronics
RS3A
draasch
Gold - Posts: 2,172
Posted: April 06, 2003 at 9:57 PM / IP Logged
you may not be getting a strong enough ground to trigger the remote start.
what are you using as the host or main unit??
alarm, factory keyless..
i believe the RS3A is for a add on remote start.
let me know what you have and im sure we can get you up and running......
Good Luck
David
Ace Security
813-376-9778
Tampa
ShaunD912
Copper - Posts: 140
Posted: April 07, 2003 at 10:40 AM / IP Logged
It's an RS3A add on remote start. I'm using the factory keyless entry in a 96 lumina.
draasch
Gold - Posts: 2,172
Posted: April 07, 2003 at 7:24 PM / IP Logged
now that i know what you have, i will get some more info for you.
Good Luck
David
Ace Security
813-376-9778
Tampa
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
