gmbp vs gmdlbp
kgerry
Platinum - Posts: 3,455
Posted: December 03, 2009 at 12:45 PM / IP Logged
The GMBP is discontinued but is still listed on the Bypasskit website as an option for many PL II vehicles. Can we use a GMDLBP on these vehicles even though it is not listed if all we want it to do is bypass the Passlock or Passkey circuit? (not do doorlocks)
If it will work, do we just disregard the vehicle platform selection?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
JWorm
Platinum - Posts: 2,208
Posted: December 03, 2009 at 6:49 PM / IP Logged
It will work fine. If you don't hook up the lock/unlock wires it just won't attempt to send any lock/unlock commands to the databus.
I'm not sure how you would program it. Mode 5 says Paslock only. I would probably try that.
Are you trying to use it on a vehicle that does not have power locks?
robertsc
Copper - Posts: 337
Posted: December 03, 2009 at 7:22 PM / IP Logged
Yes platform 5 is what you use for vehicles not listed.
Thing with the gmpdbp is that it dosn't lose programming when power is disconnected like the gmbp does.
kgerry
Posted: December 04, 2009 at 8:24 AM / IP Logged
thanks guys... i have a ton of them in stock..... so programming Mode 5 should cover PL II and PK/PK3 vehicles? even if not list on the mode selection list (Montana van, Venture, etc, etc) basically any vehicle that lists a GMBP as a viable bypass?
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
