2010 gmc sierra
Brad Eyben
Member - Posts: 33
Posted: December 03, 2009 at 4:51 PM / IP Logged
Hi all, can anybody offer up the wiring for a 2010 GMC Sierra.
Platinum - Posts: 13,672
Posted: December 03, 2009 at 6:49 PM / IP Logged
For the whole truck?
Brad Eyben
Member - Posts: 33
Posted: December 03, 2009 at 8:09 PM / IP Logged
Remote start, alarm please
Brad Eyben
Member - Posts: 33
Posted: December 22, 2009 at 10:52 AM / IP Logged
I'll answer my own post if that's OK.
I installed an UltraStart 3285XR Starter and used a iDatalink ADS-AL CA.
Which has to be flashed with the correct GM Firmware.
This selection allows a data2data connection with the vehicle eliminating a lot of wiring.
I'll include only the wiring I required.
RS UNIT
12Volt      Red back of the fuse box
ING        Pink Pin 14 (light green conn) BCM carefull there are also pink at pins 17 and 24 or you can get this from the ing switch harness.
ACC        Brown Pin 21 (light green conn) BCM or you can get this from the ing switch harness.
STARTER     Not required
TACH        Not Required
LOCK/UNLOCK Not Required
DOOR/HOOD   Not Required
BRAKE       Light Blue/White Pin 6 (brown conn) BCM carefull there is also Light Blue/white at pin 4 or you can get this at the brake pedal switch.
PARKLIGHT   Dark Blue Pin 24 (brown conn) BCM carefull there is also Dark Blue at pin 11
HORN        Tan Pin 18 (brown conn) BCM carefull there is also Tan at pin 21
BYPASS UNIT
12VOLT      Same as RS conn
PASSLOCK    Pink/Black Pin 2 (Light green conn) BCM
DATA        Dark Green Pin 10 (light blue conn) BCM carefull there is also Dark Green at pin 11
PK3        Cut and conn proper ends of Brown at PK3 module conn near ignition switch.
Notes:
Next install I'm going back to a compustar RS. I don't care for the LCD remote included in this package.
Easy install completely under the dash with great access to BCM and IGnition switches.
If looking at the wire side of the BCM connectors (the side the wires go into) the numbering system starts at the top (side with the spring clip), with 1 at the left and goes right then down to the next row.
Be sure to disconnect the vehicle battery before unplugging BCM Connectors.
Don't forget the horn even if you don't want it because with this RS you need it for programming.
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
