2005 dodge stratus remote starter
Welcome Guest :)
slobalt
Member -
Posted: December 08, 2009 at 11:57 AM / IP Logged
I purchased a commando EZ-2500 remote starter w/keyless entry for my mom's 2005 dodge stratus sedan. im looking for a wiring diagram and was also wondering if there were any t harnesses available so i dont need to splice directly into the vehicles wires. also wondering if there is any other information i need.
ceasar326
Copper -
Posted: December 08, 2009 at 1:31 PM / IP Logged
KEY | T-HARNESS | IMMOBILIZER |
CHRY KEY-1 | CHR-2 | TRANSPONDER, REQUIRES 791 BYPASS and EXTRA IGNITION KEY (Some Vehicles) |
PART | COLOR | LOCATION |
12 VOLT CONSTANT | PINK/BLACK (+) | IGNITION SWITCH HARNESS |
STARTER | YELLOW (+) | IGNITION SWITCH HARNESS |
STARTER 2 | N/A | |
IGNITION 1 | BLUE (+) | IGNITION SWITCH HARNESS |
IGNITION 2 | GREEN/ RED (+) 20 Gauge wire, 1 of 2, use the one that tests as Ignition | IGNITION SWITCH HARNESS |
IGNITION 3 | N/A | |
ACCESSORY /HEATER BLOWER 1 | BLACK/ ORANGE (+) | IGNITION SWITCH HARNESS |
ACCESSORY /HEATER BLOWER 2 | BLACK/ WHITE (+) or BLACK/ BLUE (+) (Normally not used) | IGNITION SWITCH HARNESS |
KEYSENSE | N/A | |
PARKING LIGHTS ( - ) | N/A | |
PARKING LIGHTS ( + ) | BLACK / YELLOW (+) | IN DRIVERS KICK PANEL |
POWER LOCK | WHITE/ DARK GREEN (1-Wire Door Lock System) See NOTE *1 | @ BCM, Connector C4 Pin 15, See NOTE *3 |
POWER UNLOCK | Same wire, See DIAGRAM | See DIAGRAM |
DOOR TRIGGER | See NOTE *2 | @ BCM, See NOTE *3 |
DOMELIGHT SUPERVISION | YELLOW (-), Requires Part #775 Relay | @ FRONT of FUSEBOX, 6-Pin Plug |
TRUNK RELEASE | BLACK/ WHITE (5-Wire) See NOTE *5, Requires Part #775 Relay | @ BCM, Connector C4, Pin 1, See NOTE *3 |
SLIDING POWER DOOR | N/A | |
HORN | BLACK/ RED (-) | @ STEERING COLUMN HARNESS |
TACH | ANY wire NOT GREEN/ LIGHT GREEN | @ COIL PACK |
WAIT TO START LIGHT | N/A | |
BRAKE | WHITE/ TAN (+) | @ SWITCH ABOVE BRAKE PEDAL |
FACTORY ALARM DISARM | LIGHT GREEN/ ORANGE (+) See NOTE *4 | @ BCM, Connector C4, Pin 4, See NOTE *3 |
ANTI-THEFT | CHRYSLER'S SENTRY KEY (GRAY KEY ONLY) A TRANSPONDER SYSTEM | TRANSPONDER @ IGNITION SWITCH TUMBLER |
EXTRA INFORMATION |
NOTE *1 this vehicle uses a 1-Wire Door Locking System, the LOCK requires a (+)Positive thru a 620 Ohm Resistor and the UNLOCK requires a (+)Positive thru a 2700 Ohm Resistor, some units will also require 2 extra relays Part #775, to connect, See DIAGRAM NOTE *2 the DRIVERS DOOR is a TAN (-) Pin 5 the PASSENGER DOOR is a TAN/RED (-) Pin 6 the DRIVERS REAR DOOR is a TAN/ORANGE (-) Pin 7 and the PASSENGER REAR DOOR is a TAN / YELLOW (-) Pin 8 when connecting to an ALARM SYSTEM use all 4 DOOR TRIGGER wires and DIODE ISOLATE. to connect, See DAIGRAM NOTE *3 the BCM (Body Control Module) is attached to FUSE/RELAY BOX located under the drivers side of the dash NOTE *4 the FACTORY DISARM wire requires a (+)Positive thru a 750 ohm Resistor and an extra relay part #775, to connect, See DIAGRAM NOTE *5 the TRUNK RELEASE System on this vehicle is a 5-Wire Type and will require an extra Relay part #775, to connect, See DIAGRAM. |
Sunday, May 19, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
