overhead dvd player in kia borrego
jtl6060
Posted: December 08, 2009 at 3:54 PM / IP Logged
  i'm having a problem wiring my dvd player to the door switch on my 2009 kia borrego.  i ran a wire to the ignition to run the dvd player.   tied in the dome light to the 12v feed from the battery (white wire).   i attached  the ground to the black wire.  when i attach the door switch wire from the dvd player to the door switch wire from the vehicle(yellow) the unit works backwards.  when the door is closed the light turns on.  when the door is open the light turns off.  for some reason the door switch wire from the vehicle recieves 12v while the doors are closed and loosing power when the doors open.  i did a continuity test on the original dome light and when the switch is turned  on to door, i get continuity from the wires i'm using for the dome light on/off button(white)  on the dvd unit and the yellow wire which i'm assuming is the door switch.  the only thing i can think of doing is splicing off the rear dome light, but i'm thinking it's probably wired the same way.
boxhead78
Copper - Posts: 84
Posted: December 08, 2009 at 9:13 PM / IP Logged
you have to disconnect that wire from the ignition that is tied into the dome light
boxead78
jtl6060
Posted: December 09, 2009 at 7:42 AM / IP Logged
what does that have to do with it?  please elaborate
tommy...
Gold - Posts: 1,901
Posted: December 10, 2009 at 12:05 AM / IP Logged
Im sorry its late...But the Kia's door triggers are negative right...?! I'm guessing you do not have access to a DMM...??? I would try to invest in one...Not sure where you're at...But Harbor Freight sells them for $5...How are you checking continuity...?
All Door Trigger...USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIREoverhead dvd player in kia borrego - Last Post -- posted image.
overhead dvd player in kia borrego - Last Post -- posted image.LF LatchYELLOW(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
overhead dvd player in kia borrego - Last Post -- posted image.RF LatchBLUE/ORANGE(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
overhead dvd player in kia borrego - Last Post -- posted image.LR LatchPINK(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
overhead dvd player in kia borrego - Last Post -- posted image.RR LatchORANGE(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
M.E.C.P & First-Class
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
