2006 Pontiac Torrent Alarm/Remote Start Wiring
purevision
Member - Posts: 10
Posted: December 12, 2009 at 12:15 PM / IP Logged
Hi does anyone have the wiring diagram for this... There is a post on here but it does not have the locks, door triggers, tach, or others... Thanks for your help!
shaggy12volt
Copper - Posts: 164
Posted: December 12, 2009 at 1:01 PM / IP Logged
2006 Pontiac TorrentLast Update:  2/12/2009
CircuitWire ColorLocation
  Constant 12 voltsRED / WHITE (2)IGN SWITCH HARNESS
  Ignition 12 voltsPINKIGN SWITCH HARNESS
  StarterNOT NEEDED
  Dome LightDR.FRNT RED / BLACK,ALL OTHERS TAN/WHITE (-) AT BCM *
  Driver's Front Door Pin
  Pass Front Door Pin
  Driver's Rear Door Pin
  Pass Rear Door Pin
  Trunk PinORANGE / BLACK (-)AT BCM 24PIN PINK CONN.
  Parking LampBROWN (+)AT BCM 24PIN GREY CONN.
  LockLT BLUEAT BCM 16PIN GREY CONN. #202
  UnlockWHITEAT BCM 16PIN GREY CONN. **
* BCM Located Behind Air Control Unit In Center Console, Use Bothe RED / BLACK and TAN/WHITE (-) And Diode Isolate ** Passenger Doors Only. Driver Door Is GREEN In Same Connector,Diode Isolate
#202-See Positive Pulse Door Lock Diagram
CLICK HERE TO SEE AVAILABLE DOORLOCK INTERFACE KITS
  Tach SignalBROWN / WHITEAT PCM OR IGNITION COIL *
  Ignition #2N/A#238
  Ignition #3N/A
  AccessoryORANGEIGN SWITCH HARNESS
  Accessory #2
  Accessory #3
  Starter #2
  Neutral SafetyLT BLUE (-)AT BCM 24PIN PINK CONN
  Brake LightLT BLUE (+)AT SWITCH ABOVE PEDAL
  Parking Brake
  Clutch Pedal
  Reverse LightLT GREEN (+)AT UNDERHOOD FUSE BOX
  Rear DefrostN/A
* PCM Located On Drivers Side Of Motor, In Front Of ECU
#238- See G.M. Passlock II Diagram ** Additional Accessory Wire BROWN Is Required If This Wire And The ORANGE Wire Is Not Powered You Will Get A Pass Lock Light. In Addition To This The GREEN Key Sence Wire Must See A Ground When Running If Not The Service Required Light Will Come On. Its The Light With The Car And Wrench On It.
CLICK HERE TO SEE AVAILABLE IMMOBILIZER BYPASS KITS
Page 2
  Window Up D\ DK BLUE P\ DK BLUE D\ DK GREEN P\ LT GREEN @ MAIN #211
  Window Down F/ BROWN F/ BROWN R/ VIOLET R/ VIOLET SWITCH
  KeysenseLT GREEN (-)AT BCM 24PIN GREY CONN.
  Trunk ReleaseN/A
  OEM HornTAN (-)STEERING COLUMN HARNESS
  HeadlightsDK BLUE (CHASSIS -)AT BCM 16PIN GREY CONN.
  OEM Alarm ArmN/A
  OEM Alarm DisarmLT GREEN (+)AT BCM 16PIN GREY CONN. *
  Vehicle Speed Sense
* LT GREEN Will Also Unlock Driver Door
#211- See Reversal Rest At Ground Window Diagram
  OEM Keyless Module-
  Motor Lock
  Motor All Unlock
  Motor Driver Unlock
  (disarm defeat)
  OEM Lock Relays-
  Add On Security Type-
  Left Front Speaker(+); Size:
  Left Front Speaker(-); Size:
  Right Front Speaker(+); Size:
  Right Front Speaker(-); Size:
  Left Rear Speaker(+); Size:
  Left Rear Speaker(-); Size:
  Right Rear Speaker(+); Size:
  Right Rear Speaker(-); Size:
TECH NOTES:
  Module P/N  Firmware
  OL-DB-GM  OL-DB-GM GM All-in-One Doorlock Interface and more (V1)
  OL-IB-PL  OL-IB-PL GM VATS/Passlock/PK3/PK3+ (V2.2)
  OL-MDB-ALL  OL-AL(MDB)-GM4 GM J1850 Doorlock Interface and more (V1.9)
  OL-MDB-ALL  OL-AL(MDB)-GM4 GM J1850 Doorlock Interface and more (V2)
  OL-MDB-ALL  OL-AL(MIB)-PL GM VATS/Passlock/PK3/PK3+ Override (V2.2)
  OL-MDB-GM1  OL-MDB-GM4 GM J1850 Doorlock Interface and more (V1.9)
  OL-MDB-GM1  OL-MDB-GM4 GM J1850 Doorlock Interface and more (V2)
  OL-MDB-GM1  OL-MIB-PL GM VATS/Passlock/PK3/PK3+ Override
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
purevision
Member - Posts: 10
Posted: December 12, 2009 at 5:19 PM / IP Logged
thanks
gumis
Posted: December 26, 2009 at 10:38 PM / IP Logged
ok. everythink is fine.. but i cant find orange wire... and i got extra wihte and white w/black line....
hmmm so starter wires are not needed???
accesory 2 is brown right????
gumis
Posted: December 26, 2009 at 10:39 PM / IP Logged
aha my torrent is 2007. thanks a lot
shaggy12volt
Copper - Posts: 164
Posted: December 31, 2009 at 8:07 PM / IP Logged
let me know if you need anything else
The Shagmaster
