python 592 2 way remote start
icarus_icarus
Copper - Posts: 229
Posted: March 13, 2010 at 9:17 PM / IP Logged
May I ask what d2d and w2w is please?
·Ï¢årµ§·
python 592 2 way remote start - Page 3 - Last Post -- posted image.
jeremytravis
Copper - Posts: 62
Posted: March 13, 2010 at 9:18 PM / IP Logged
W2W
**advanced mecp certified
jeremytravis
Copper - Posts: 62
Posted: March 13, 2010 at 9:24 PM / IP Logged
Its the way you connect a bypass module (wire to wire) or (data to data)
icarus_icarus
Copper - Posts: 229
Posted: March 13, 2010 at 9:26 PM / IP Logged
Ah, thanks. Lots to learn :)
·Ï¢årµ§·
Moderator - Posts: 12,488
Posted: March 13, 2010 at 9:29 PM / IP Logged
D2D whenever I can. If I run into problems where D2D doesn't work, then I change modules and try again in D2D and if that doesn't work I resort to W2W. Using D2D saves time and makes us money in the shop. When it takes 20 minutes to do a new Dodge in D2D as oppose to 2 hours in the traditional wiring method, it's a no brainer.
tedmond
Gold - Posts: 4,610
Posted: March 13, 2010 at 9:30 PM / IP Logged
d2d - data to data which is a 4 pin connector that allows all digital communication between alarm/rs to the bypass module.
w2w - wire to wire traditional involving wiring output of the alarm/rs to the input of the bypass or data module.
Ted
Compustar Expert
Troc4434
Copper - Posts: 68
Posted: March 22, 2010 at 8:10 PM / IP Logged
hey guys I need to know good spots to mount a few sensors. I have a Chrysler 300c need spots that are most effective. I have a backup battery, tilt sensor, glass break sensor, and a mini siren for inside the car. what are good locations for these. also for the tilt sensor what zone or (-)trigger wire is best for this one?
Troc4434
Copper - Posts: 68
Posted: September 07, 2010 at 1:48 AM / IP Logged
hey guys it been awhile since Ive been on. My question is where do I find the low can and high can wires( twisted together they say)? I know I see the obd2 plug under the steering wheel area which has wire coming from it. but not sure what color. my canmax400 diagram which is the type b install says the the can low is white, WHITE/ gray or white pink, which I dont see none of these colors. the can high is WHITE/ orange which I dont see. it says kick panel, I dont see anything there. These are the last to wires I need to hook up. also does any of you guys every cut the factory ignition wire for the starter kill? the green wire from the remote start do you guys hook it up or just leave it unhooked?
Page of 3
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
