ads rng gm3
pipes15
Member - Posts: 45
Posted: January 06, 2010 at 8:49 PM / IP Logged
Hello, I have to install one of these ring modules this weekend anyone put one in yet?  Any problems/complications?   Any tips would be greatly appreciated!
pipes
mikvot
Gold - Posts: 1,043
Posted: January 06, 2010 at 9:03 PM / IP Logged
Year, Make and Model of vehicle would help a ton. One bypass may work perfectly on one vehicle, and may have problems on another, so without knowing this info, it's hard to say. We may also be able to recommend other bypass units that we have experience with. I use only idatalink stuff now, but have not used that module.
pipes15
Member - Posts: 45
Posted: January 06, 2010 at 9:39 PM / IP Logged
hey mikvot,  thanks for the reply.  I am installing in a 2008 gmc sierra.  bypass module ADS-DL with the ADS-RNG-GM3 (key ring)  Type 2 installation.
pipes
mikvot
Gold - Posts: 1,043
Posted: January 06, 2010 at 10:18 PM / IP Logged
Ok...now we're on the same page. I have not used the optional ring for any installs yet. I have only used the type 3 install with this module on Chevy/Gmc, and I have not had any comebacks. I assume you are using type 2 because of the lower current draw? Even if you are using the type 2, it should be pretty much straigh forward. If you have a problem, call Idatalink. Those guys are awesome, and offer some of the best tech support in the industry.
pipes15
Member - Posts: 45
Posted: January 06, 2010 at 10:57 PM / IP Logged
thanks for your help mikvot.
pipes
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
