going crazy remote start problem
chisam14
Member - Posts: 37
Posted: January 09, 2010 at 11:59 PM / IP Logged
I am installing a Bulldog RS and PS2 bypass in a 03 Tahoe. I have checked every lead twenty times ensuring proper connectivity, re-learned the bypass, and tried other options for hours with no luck. It remote starts perfect and you think mission accomplished then it dies after 10 seconds of run-time. It is telling me to hook up a factory alarm disable wire in the kick-panel, never had to do this before but it didnt help anyway. If it were a bypass problem I would figure it to not start at all. I can feel a relay kick out in the box when it shuts off after ten seconds.
zerepdivad
Silver - Posts: 605
Posted: January 10, 2010 at 12:39 AM / IP Logged
Where did you get your tach signal from? I'm gonna assume you didn't use it, and tell you to get your tach behind the cluster and it will be a white wire. It'll be your only white wire there.
A DMM is a beautiful thing.
Posted: January 10, 2010 at 3:02 AM / IP Logged
I'd bet my ex-wives life that that tach either hasn't been connected properly or learned properly or both.
Being less facetious any R/S that starts and runs for 5-15 secs then cuts out means tach isn't right.
The fact that it starts at a means you've done everything else pertaining to the R/S correctly including the by-pass if fitted.
chisam14
Member - Posts: 37
Posted: January 10, 2010 at 1:20 PM / IP Logged
I did not use a tach wire. It had an option to run tach-less so that's what I did. I haven't had to use a tach lead before so I didnt think I would have to now. Thanks for the help, I'll give it a shot
tommy...
Gold - Posts: 1,901
Posted: January 10, 2010 at 2:35 PM / IP Logged
Hook up tach...Im with Howie and davidperez...I'll bet Howie's ex-wife too...!
M.E.C.P & First-Class
dvaldez0989
Copper - Posts: 98
Posted: January 10, 2010 at 6:17 PM / IP Logged
How did you hook up your door triggers if you used the dome light change it. I had this problem too and I changed it to the proper way and never had a problem
chisam14
Member - Posts: 37
Posted: January 12, 2010 at 10:15 AM / IP Logged
Hooking up the tach lead and setting it in tach mode did the trick. Thanks guys. I guess howie's ex-wife gets to live lol
Posted: January 12, 2010 at 11:45 AM / IP Logged
Good to hear, I've posted a note on tach learning because we've had a few posts like this recently.
Actually right now I wish I was in contact with her because my daughter's going through a nasty divorce and she needs the Rotweiller right now!
t&t tech
Platinum - Posts: 2,608
Posted: January 12, 2010 at 2:51 PM / IP Logged
Howie i hope that isn't the rotweiler you always leave in the back seat!
commit your way to jehovah and he will act in your behalf. psalms 37:5
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
