2010 ford f 150
ben@atas
Posted: January 20, 2010 at 3:58 PM / IP Logged
I am installin a Car Starter on a 2010 Ford F-150, and I can't find the tach wire anywhere. My wire guide shows at ignition coil (BROWN / wire). Anybody have any ideas?? Or can I find it behind the instrument cluster?? Any help would be greatly apprectiated....thanks
ben
Ben Ibarra
Advanced Tire & Auto Svc
Moderator - Posts: 12,488
Posted: January 20, 2010 at 4:53 PM / IP Logged
Either go to an injector or program the remote starter to tachless and set crank time for 2-4 seconds. There's OEM anti grind on these trucks since 2004 and if you have a unit capable of extending the crank time, it saves you time running wire into the engine.
Platinum - Posts: 7,783
Posted: January 20, 2010 at 7:59 PM / IP Logged
If you go with tach, at any fuel injector, attach to  any color wire not  (common) blue.
ben@atas
Posted: January 22, 2010 at 8:56 AM / IP Logged
thanks guys!! i tried that yesterday and it worked perfect!! i went straight to the feul injector wire and it fired right up!!....thanks again i really appreciate the help..
Ben Ibarra
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
