rear defrost in 2003 honda crv
ffyter
Member - Posts: 48
Posted: February 08, 2010 at 10:47 AM / IP Logged
I just installed a Viper 5701 and am having issues getting the rear defrost to trigger on my Aux1 output. I tried changing the output from latched to timed and it still won't turn on. The wire I hooked into shows 12 volts and goes to 0 when turned on. Any ideas would be great.
Nick
monty_77
Copper - Posts: 491
Posted: February 08, 2010 at 10:56 AM / IP Logged
it should be a negative polarity wire, yellow/black behind the switch
should be a pulse not a latch
not sure if it will light up the indicator or not.
ffyter
Member - Posts: 48
Posted: February 08, 2010 at 11:28 AM / IP Logged
If I use the aux 1 channel is Validity or Timed the sames as pulse? Or should I just use the defogger output? The reason I don't really want to use this one as I don't want it to activate at 55 degrees everytime I remote start.
monty_77
Copper - Posts: 491
Posted: February 08, 2010 at 11:56 AM / IP Logged
validity should work just push the button and then it will shut off only active as long as you push the button
ffyter
Member - Posts: 48
Posted: February 08, 2010 at 3:54 PM / IP Logged
Thank you for the help! It turns out that I had to switch it to latched and as you mentioned, the light does not come on letting you know that it is on.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
