600 esp
01burb
Member - Posts: 7
Posted: February 20, 2010 at 3:32 PM / IP Logged
I have the 600 ESP installed in my 1987 Firebird.  It has been working great until today, last used 3 days ago..  The alarm is armed but the remotes (2) won't disarm or do anything, no chirps, but when the door is opened the alarm sounds.  I replaced the battery still nothing.  Any Ideas?  Thanks George
bambam3030
Member - Posts: 19
Posted: February 20, 2010 at 5:11 PM / IP Logged
You can try to reprobram the alarm remotes by First turning the alarm off manualy with the valet switch. Find the button then turn your key to the on position and press in the valet button let it go and press it in and hold it. that should turn your alarm off. Then turn your key on and press your valet button in let it go and press it back in and hold it. while holding the button in press the lock button on the key pad that you are programing and you should hear the alarm chirp at you. If this doesnt work it could be bad remotes but I dobt two went bad at the same time. It could also be the alarm brain it self, You would have to check all the power wires and make sure they are still connected and geting the proper voltage. hope this helps.
bam
01burb
Member - Posts: 7
Posted: February 20, 2010 at 7:53 PM / IP Logged
Thanks I'll try it in a couple of days when I get back to the car.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
