2009 Chrysler Town & Country Alarm/Stereo Wiring
martinbernard
Posted: March 29, 2010 at 8:27 AM / IP Logged
Can somebody help me with the wire schedule for a town & country 2009 i want to install a alarmsystem that hooks up to the central lookingsystem.
2009 Chrysler Town & Country Alarm/Stereo Wiring -- posted image.
Platinum - Posts: 7,783
Posted: March 29, 2010 at 6:42 PM / IP Logged
This wire guide is for the US market Town & Country.  There could be some differences with a Euro spec vehicle....
 2009 CHRYSLER TOWN & COUNTRY MINIVAN WITH 3.3L ENGINE AND 4-SPEAKER AUDIO SYSTEM
 Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  YELLOW/RED  (+)  RADIO HARNESS
Accesory
   THIS VEHICLE USES THE CAN DATA SYSTEM FOR ACCESSORY TURN ON
 Ground  BLACK/ WHITE  (-)  RADIO HARNESS
 LF Speaker (+)  GRAY/VIOLET
 LF Speaker (-)  GRAY / YELLOW
 RF Speaker (+)  DARK GREEN/ VIOLET
 RF Speaker (-)  DARK GREEN/ YELLOW
 LR Speaker (+)  GRAY/LIGHT GREEN
 LR Speaker (-)  GRAY/DARK GREEN
 RR Speaker (+)  DARK GREEN/ LIGHT GREEN
 RR Speaker (-)  DARK GREEN/ GRAY
 Steering Cntrls  YES
 Speed Cntrl  NO
 Radio Security  YES
Security
 Battery  LIGHT BLUE/RED  (+)  IGNITION SWITCH HARNESS
   THIS WIRE ONLY SUPPLYS 10 AMPS OF CURRENT, FOR HIGH CURRENT APPLICATION GO DIRECTLRY TO THE BATTERY
 Ignition 1  PINK/WHITE  (+)  WIRELESS IGNITION MODULE IN STEERING COLUMN
 Starter 1
   THIS VEHICLE USES THE CAN DATA NETWORK FROM THE WIRELESS IGNITION MODULE IN THE STEERING COLUMN FOR REMOTE START FUNCTIONS. USE AN APPROPRIATE ADAPTOR FROM A SECURITY MANUFACTURER FOR REMOTE START
 LF Latch  VIOLET  (-)  AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
 RF Latch  VIOLET/WHITE  (-)  AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
 LR Latch  VIOLET/GRAY  (-)  AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
 RR Latch  VIOLET / YELLOW  (-)  AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
 Trunk Trigger  VIOLET  (-)  AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
 Parking Lights  WHITE/ LIGHT GREEN (L) & WHITE/ TAN (R)  (+)  AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
Convenience
 Parking Brake  DARK GREEN / WHITE  (-)  AT VEHICLE PARKING BRAKE SWITCH
Remote Start
 Starter 1
 Anti-Theft Type  DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Brake Lights  WHITE/ TAN  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  WHITE/ LIGHT GREEN  (+)  AT TIPM UNDER HOOD
 Horn  DARK GREEN/ VIOLET  (-)  IN HARNESS AT STEERING COLUMN
Modules
 WIRE  LOCATION
 Please select another category
Doorlocks/Windows
 Power Unlock  VIOLET/DARK GREEN  (-)  IN HARNESS TO DRIVER DOOR IN DRIVER KICKPANEL
   UNLOCK IS (-) THROUGH A 100 OHM RESISTOR, SAME WIRE FOR LOCK, MUST USE RELAYS
 PowerLock  VIOLET/DARK GREEN  (-)  IN HARNESS TO DRIVER DOOR IN DRIVER KICKPANEL
   LOCK IS (-) THROUGH A 330 OHM RESISTOR, SAME WIRE FOR UNLOCK, MUST USE RELAYS
 LF Window Up  ORANGE / LIGHT GREEN  (REV)  AT DRIVER WINDOW CONTROL SWITCH
 LF Window Dn  ORANGE / WHITE  (REV)  AT DRIVER WINDOW CONTROL SWITCH
 RF Window Up  ORANGE / TAN  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 RF Window Dn  ORANGE / GRAY  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 LR Window Up  ORANGE / WHITE  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 LR Window Dn  ORANGE / GRAY  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 RR Window Up  ORANGE / LIGHT BLUE  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 RR Window Dn  ORANGE / DARK BLUE  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
