2010 Sentra SER Alarm/Remote Start/Stereo Wiring
alokke
Posted: April 04, 2010 at 3:21 PM / IP Logged
Does anyone have the wiring diagram for this vehicle? I assume it would be the same for the regular Sentra. Thanks in advance.
Platinum - Posts: 7,786
Posted: April 04, 2010 at 4:00 PM / IP Logged
Bulldog Security web site lists the 2010 Sentra.  They say the 2007 thru 2010 are the same and don't differentiate the SER model.
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Here is AudioVox info:
 Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  YELLOW  (+)  RADIO HARNESS
 Accesory  GRAY  (+)  RADIO HARNESS
 Ground  CHASSIS  (-)  RADIO CHASSIS
   THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
 LF Speaker (+)  BLUE
   THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
 LF Speaker (-)  WHITE
 RF Speaker (+)  PINK
   THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
 RF Speaker (-)  RED
 LR Speaker (+)  GREEN
 LR Speaker (-)  VIOLET
 RR Speaker (+)  BLUE
 RR Speaker (-)  YELLOW
 Amp Location
   SEE THE ROCKFORD® AUDIO TRIM FOR AMPLIFIER INFORMATION
 Steering Cntrls  NO
 Speed Cntrl  NO
 Radio Security  YES
 Security
 Battery  GREEN  (+)  IGNITION SWITCH HARNESS
 Ignition 1  YELLOW  (+)  IGNITION SWITCH HARNESS
 Starter 1  WHITE  (+)  IGNITION SWITCH HARNESS
 All Door Trigger
   YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS.
 Domelight Super  RED  (-)  AT BCM MODULE TO RIGHT OF RADIO BEHIND DASH
 LF Latch  LIGHT BLUE  (-)  IN HARNESS IN DRIVERS KICKPANEL
 RF Latch  BROWN / WHITE  (-)  IN HARNESS IN PASSENGER KICKPANEL
   MAY ALSO BE BROWN
 LR Latch  RED / WHITE  (-)  IN HARNESS IN DRIVER KICKPANEL
   MAY ALSO BE BROWN / WHITE
 RR Latch  RED / WHITE  (-)  IN HARNESS IN PASSENGER KICKPANEL
   MAY ALSO BE WHITE
 Trunk Trigger  WHITE/ GREEN  (-)  IN HARNESS IN DRIVER KICKPANEL
 Alarm Disarm
   THERE IS AN OPEN PIN IN THE KEYLESS ENTRY CONNECTOR NEXT TO THE VIOLET TRUNK RELEASE WIRE,
   THIS WILL DISARM THE FACTORY ALARM IF EQUIPPED WITH A (-) PULSE
 Parking Lights  RED  (+)  IN HARNESS IN DRIVER KICKPANEL
 Convenience
 All Hazrd Lights  YELLOW  (-)  AT VEHICLE HAZARD SWITCH
 Wipers-Lo  BLUE  (+)  AT VEHICLE WIPER MOTOR
 Wipers-Hi  BLUE/BLACK  (+)  AT VEHICLE WIPER MOTOR
 Parking Brake  GREEN  (-)  AT PARKING BRAKE SWITCH
   ALSO GRAY IN HARNESS TO REAR OF GAUGES
 Trnk Release  RED  (+)  IN HARNESS IN DRIVER KICKPANEL TO REAR
 Remote Start
 Accessory 1  RED  (+)  IGNITION SWITCH HARNESS
 Accessory 2  BLUE  (+)  IGNITION SWITCH
 Anti-Theft Type  NISSAN NVIS® VEHICLE IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN
ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Key Sense  RED / BLUE  (+)  IGNITION SWITCH HARNESS
   **THIS WIRE MUST BE ENERGIZED DURING REMOTE START**
 Tachometer  RED  (-)  AT ECM MODULE UNDER HOOD
 Speed Sense  GRAY  (AC)  IN HARNESS TO GAUGES
   MAY ALSO BE BLUE/WHITE
 Brake Lights  RED / GREEN  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  WHITE/ BLACK  (+)  IN HARNESS IN DRIVER KICKPANEL TO REAR
 Horn  GREEN  (-)  IN HARNESS HIGH IN DRIVER KICKPANEL
   MAY ALSO BE GREEN / WHITE
 Alarm Indicator  LIGHT BLUE  (-)  AT BCM MODULE TO RIGHT OF RADIO BEHIND DASH
 Modules
 WIRE  LOCATION
 Module 1  ECM- UNDER HOOD NEAR BATTERY
 Module 2  ABS MODULE UNDER HOOD NEAR PASSENGER STRUT TOWER
 Module 3  BCM MODULE- TO RIGHT OF RADIO BEHIND DASH
 Module 4  KEYLESS MODULE- ABOVE GAS PEDAL
 Doorlocks/Windows
 Power Unlock  PINK  (-)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 PowerLock  RED  (-)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 Driver Mtr Unlock  GREEN  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 Driver Mtr Lock  VIOLET  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
 Pas Mtr Unlock  GREEN  (REV)  IN HARNESS IN PASSENGER KICKPANEL TO DOOR
 Pas Mtr Lock  VIOLET  (REV)  IN HARNESS IN DRIVER KICKPANEL TO DOOR
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
