need one input three state output
terrybk95631
Posted: April 13, 2010 at 3:23 PM / IP Logged
I searched and found a little but nothing I could convert to a diagram. This is for a car heated seat circuit.
I need a relay(s) configuration that uses a grounded input (switch closes to ground) and will provide two outputs in sequence with the third trigger clearing the outputs.
Power on - Out 1 and Out 2 off (I need to make sure neither output is on when you turn on the key.)
Press 1 - Output 1 on - Output 2 off.
Press 2 - Output 1 off - Output 2 on.
Press 3 - Both outputs off.
Another press starts over at Press 1.
Any suggestions?
anonymous1
Copper - Posts: 151
Posted: April 13, 2010 at 4:59 PM / IP Logged
I don't think you need to press anything to get your results.
Use a 3 way rocket switch.
UP (on) is one of your choices
DOWN (on) is one of your choices
MIDDLE (off) one of your choices.
You need a single DPDT relay to handle both UP and DOWN.
One of the smart people will be along soon to critique my foggy logic :D
Didnt I answer this question already recently?
:D
terrybk95631
Posted: April 13, 2010 at 5:14 PM / IP Logged
anonymous1 wrote:
...Didnt I answer this question already recently?
Not for me.
:D
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
