2011 sonata
mobiletint
Member - Posts: 47
Posted: April 16, 2010 at 7:32 PM / IP Logged
The ignition harness is a breeze... be careful its delicate, we had one pop the key cylinder apart. Took 20min to put it back together, no thanks..
Anyone get DOORLOCKS to work on this car yet??
Platinum - Posts: 7,783
Posted: April 17, 2010 at 12:22 PM / IP Logged
Yes.  There is a White 24 pin connector at the botton right corner of the Fuse Box.  You can remove the lower dash panel for better access or just disconnect it and allow it to hang.  Here is a picture.
2011 sonata -- posted image.
mobiletint
Member - Posts: 47
Posted: April 17, 2010 at 9:19 PM / IP Logged
Youre the bomb, that is the best info in the world. Thanks so much.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
