power antenna and spdt relay
trinidad23
Member - Posts: 31
Posted: May 21, 2010 at 11:36 AM / IP Logged
my metra roadwork aftermarket antenna relay its shot and will not let the antenna go down. the antenna goes up but not down and i cannot find the original 5a/30vdc godsky 202-d relay. it is possible to use a regular spdt relay? can you guys help me with the wiring since i'm not sure to which of the post in the relay i have to plug it. thanks
oldspark
Gold - Posts: 4,913
Posted: May 22, 2010 at 3:02 AM / IP Logged
To do that, it's probably 2 separate relays isn't it? (2 x DPST or DPDT?)
You need to imitate the centre-off polarity reversing switch (assuming it's a 2-wire motor; if 3 wire 2 x SPST should do).
I'd expect an appropriate diagram in the relay (circuits) section....
trinidad23
Member - Posts: 31
Posted: May 27, 2010 at 4:24 AM / IP Logged
i'm still confuse on how to hook it up, the power antenna has three wires and i removed the factory relay and found it to be burn. the anteena stay in the up and i need to know if and how to hook it up to a relay so i can get it to go down. or if i can use a toggle switch. sorry ,but i need a more specific instructions on to what goes where. liked antenna wire go to the different locations on the sp relay. thanks for any help.
oldspark
Gold - Posts: 4,913
Posted: May 27, 2010 at 6:44 AM / IP Logged
You'll need to tell me what the wires are.
I assume one is GND (probably black) and the other 2 are +12V as required - one for up, the other for down, but NOT both at the same time. (IE - connect the GND, then with a +12V wire, try each "other" wire one at a time.)
You could test that. I suggest using a 10A fuse in the +12V line.
