batteries, 98 gmc, multiple amplifiers
spacecase
Posted: June 05, 2010 at 10:53 AM / IP Logged
Hi I been getting to get my truck together but would like to make sure that what I'm planning will be enough or is going to work plus a little intel on wiring with multi. batteries and amps. Okay I got a '98 Gmc ext. cab 150 alt. 0awg extreme deep cycle under hood--running 1 brutus 1600 with line driven pushing about 12 v in amp set at a 2ohm to 4 Re 10"s in ported boxes does 134.8db--I have not put everything toghter but have all but the box I'm making It is going to a wall with sealed enclosure w/just under a ft' of air space. Will have 2 brutus 1600 set to 2ohm to 8 re's  and 1 440 4 ch. Just got 3 new red top I need to know how to run these batteries and if what I'm talking about is underkill or over. I think I'll might need better alt. but just can't get fund for that just yet all this equip has taken me about 6-8 mnths to gather. Do u think if done right I might see 150db......
Thx to all will to help
anonymous1
Copper - Posts: 151
Posted: June 05, 2010 at 1:08 PM / IP Logged
No, but I think if done right your neighbors will rightfully shoot at you.
Yes for alt upgrade.
See previous thread about how to install multiple batteries and read them over and over again.
I know just enough to be dangerous. VERY dangerous.
nismo542
Copper - Posts: 62
Posted: June 05, 2010 at 10:59 PM / IP Logged
if you are going for high spl then you should do a ported box tuned to the resonant frequency best for the subs and the vehicle.  i wouldnt run red tops, you need a deep cycle battery.  i would upgrade the alternator rather than all those batterys.
oldspark
Gold - Posts: 4,913
Posted: June 06, 2010 at 4:28 AM / IP Logged
I'd argue low ESR batteries for SPL.
But if higher SPL results from higher system voltage (ie, 14.4V or higher versus 12.7 & below), then preferably copious alternator size (of engine running/charging) and/else 14V batteries (if the rules allow).
Deep cycle batteries if insufficient alternator or (lower ESR) battery capacity. (Remember - ESR increases as batteries discharge.)
spacecase
Posted: June 06, 2010 at 11:16 AM / IP Logged
thx guys  Like I said I've got a 150 alt I guess need to add another 150 and I guess the 2 redtops where a waste I have biggest deep cycle car quest sells under hood but of what I'm hearing need to put 1 readtop under hood and move deepcycle and get another for sound-----because I don't have money for another alt right now do you all think that I could even run the 2 brutuses with what I got  or would I just kill what I got????
oldspark
Gold - Posts: 4,913
Posted: June 06, 2010 at 9:01 PM / IP Logged
Under the hood is usually for crankers rather than deep cycle.
And low-ESRs under the hood are compromised by the long cables to the amp etc (ie, may as well use high CCA wet cells).
And if you have the batteries you may as well use them.
Usually they are as close to the amps as possible to avoid sags, but SPL may be different - ie, caps suppress spikes hence lowering peak power, and a battery is like a big cap.
But those experienced with SPL will have to advice on that stuff....
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
