compustar alarm 900fm
akatdog
Member - Posts: 8
Posted: June 05, 2010 at 12:42 PM / IP Logged
hi guys, i did a search but couldnt find anything, im looking for basic wiring info on the compustar alarm, i have an alarm installed now but i would like to switch to this one i have.
im just looking for basic power, ground, remote power...
tedmond
Gold - Posts: 4,610
Posted: June 05, 2010 at 6:58 PM / IP Logged
the wires are printed on the back of the manual.
if you just want power/ground
look at the large 6pin harness
BLACK - ground
RED - Constant 12v
RED / WHITE - Constant 12v
do oyu know what brain model you are installing?
Ted
Compustar Expert
akatdog
Member - Posts: 8
Posted: June 05, 2010 at 9:45 PM / IP Logged
hi, its the RF-2W900 alarm, i want to replace my old alarm with this one but having trouble with the wiring
tedmond
Gold - Posts: 4,610
Posted: June 06, 2010 at 6:02 AM / IP Logged
i meant to say the wiring is on the back of the brain itself.
so everything you need to know is there. if you need an install manual you can get it in downloads.
Ted
Compustar Expert
akatdog
Member - Posts: 8
Posted: June 07, 2010 at 12:09 PM / IP Logged
ok, my first large harness only has 4 wires? the brain says RED / power   BLACK/ ground i have those hooked up along with the siren to the brown
im just trying to get basic arm and disarm but cant get any sound from siren and the led wont even come on... are there any other wires i must hook up to get power?
91stt
Silver - Posts: 564
Posted: June 07, 2010 at 3:54 PM / IP Logged
is the siren ground attached?
how are you testing the unit?
if you are using the remote, is the antenna plugged in?
are you testing it in the vehicle or on a bench?
is there a fuse in the power wire and is it good?
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
akatdog
Member - Posts: 8
Posted: June 07, 2010 at 4:31 PM / IP Logged
im testing it in my car, the alarm i just took out worked fine but very old and limited options
yes the siren is grounded, i am using the remote, the antenna and the led are plugged in, there is a 30 amp fuse in the line and its fine
is there certain buttons too press on the remote for first use?
should the led come on?
dswift
Copper - Posts: 396
Posted: June 07, 2010 at 6:09 PM / IP Logged
Well if you didn't notice the remotes do not come preprogrammed.
Program your remotes. And you should be fine. Also if you tell us what your working with this will HELP alot.
"dont ground out!"
tedmond
Gold - Posts: 4,610
Posted: June 07, 2010 at 7:17 PM / IP Logged
the 900fm is the one with the blue or grey remotes i assume.
cycle the ignition 5 times, wait for a click, press lock, wait to hear 2 clicks then turn off ign.
you can simulate this by tapping the ign wire to constant 12v.
Ted
Compustar Expert
akatdog
Member - Posts: 8
Posted: June 07, 2010 at 7:46 PM / IP Logged
its a 1984 Z28 Camaro
yes it comes with one blue pager remote and one grey keyless remote
thanks, i will try tomorrow to cycle the ignition and see what happens.
