1999 jetta glx w/bose
TheDouche
Copper - Posts: 93
Posted: June 14, 2010 at 8:56 PM / IP Logged
as the name stats the vehicle is such. my friend purchased the vehicle and it has a bose sound system in it. he said that it was only in the back. i think its because he doesnt believe that a small amp can do the whole car but i was wondering what are the chances that they could be none bose up front? also how hard would it be to replace?
TheDouche
Copper - Posts: 93
Posted: June 16, 2010 at 11:23 PM / IP Logged
nobody knows anything about this?
91stt
Silver - Posts: 564
Posted: June 17, 2010 at 3:27 PM / IP Logged
The radio diagram I have does not show any external amplifiers for this vehicle.
Bose systems usually employ several external small amps to power all of the speakers.
The small amps work because that use driver/speaker with very low impedance so they are super efficient.
An off the shelf speaker is typically 4 ohms where Bose uses 1 ohm or less.
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
91stt
Silver - Posts: 564
Posted: June 21, 2010 at 1:39 AM / IP Logged
In response to you question via PM, it may or may not be necessary to replace the Bose speakers with Bose. If any of the speakers are good, just take a reading with an ohmmeter to give you an idea what the nominal impedance is. If they are around 4 than off the shelf speakers will probably work ok. I say "ok" because Bose is designed to work with their own components. The built in equalization may not be optimal with other drivers.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
