remote start on a 06 jetta standard
kiteman
Copper - Posts: 98
Posted: August 16, 2010 at 5:15 PM / IP Logged
I'm fixing to install a Viper remote start alarm on a 06 Jetta with a standered transmission..  Someone told me that 1. it's not a easy car, and 2. that it will always have the check engine light on cause of the clutch bypass...   The question is, has anyone ever hear of the engine light comeing on after the install and is there a fix for it... Also what is the best bypass mode for that car..   Thanks in advance
darksidecelica
Member - Posts: 30
Posted: August 20, 2010 at 8:44 PM / IP Logged
Which Viper alarm/rs are you looking at? Most the the newer ones will work with standard transmissions, just got to do a sequence of things before getting out of the car so check engine light shouldnt be an issue. This isnt too easy of a car either. Lock wires are found in the door module inside the driver door so unless you pick up the xk01, xk09, or DLPK modules to do the locks for you, you're gonna be fishing wire through a PITA door boot. It calls for a TBX key with the loop for the transponder override, so you're gonna need to give up a key. So unless you have done numerous r/s with modules before, I wouldnt attempt this install.
jbean8510
Member - Posts: 14
Posted: August 20, 2010 at 10:28 PM / IP Logged
when i worked at circuit city i tried to have one installed on my wife's 07 jetta and they could never get it to work, they couldnt find wires they needed, and ended up blowing a fuse because they used the wrong one....if you get it done post up some wiring schematics cuz id do it myself if i knew what was so weird about it
99 xp
08 350z
Posted: August 21, 2010 at 1:46 AM / IP Logged
PM Chris Luongo, I believe he wrote the definitive on MkV Golf/Jettas.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
