2000 camaro v6 cc won't work
jfmmck
Posted: August 25, 2010 at 12:11 PM / IP Logged
I removed the drive train (3.8 L & 4L60E)  including PCM, wiring and steering column from a 2000 Camaro and installed in my 50 Chevy pickup.  I can't get the cruise control to work.  I have a wiring diagram and have run every wire from the PCM, speed sensor, (accelerator pedal), engine, brake pedal, and CC switch.  All are connected correctly.  Does anyone have a suggestion as to why the CC won't work and what can I trouble shoot?
Jamie
Jamie
icearrow6
Copper - Posts: 497
Posted: August 25, 2010 at 12:28 PM / IP Logged
Was the unit tested before you removed it from the camaro?
jfmmck
Posted: August 25, 2010 at 8:30 PM / IP Logged
The car was wrecked, with 605 miles and a salvage title, so I did/couldn't drive it.  It is a drive by wire set up and everything but the cruise controll works.  The only part not installed in my truck is the instrument panel which does have a "cruise light".  Any sugestions would be appreciated.
Jamie
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
