2010 Suzuki SX4 Alarm/Remote Start Wiring
pitoaudiovisual
Copper - Posts: 388
Posted: October 15, 2010 at 2:22 PM / IP Logged
Does anyone have paperwork for a 2010 SX4 Suzuki. Im doing a remote starter in it. Thank you in advance
Confidence is the key to any project!!
chev104275
Gold - Posts: 1,427
Posted: October 15, 2010 at 2:42 PM / IP Logged
this is for an 09 but should be the same
2009 SUZUKI SX4 4DR HATCHBACK WITH 2.0L ENGINE AND 4-SPEAKER AUDIO SYSTEM
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE/ BLUE & WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN (+) IGNITION SWITCH HARNESS
Starter 1 GREEN / WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger
   USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Domelight Super WHITE (-) AT BCM MODULE
   ALSO IN HARNESS IN DRIVER KICKPANEL
LF Latch BLACK/ BLUE (-) AT BCM MODULE
RF Latch BLACK/ RED (-) AT BCM MODULE
   ALSO IN HARNESS IN DRIVER KICKPANEL, THIS WIRE COVERS THE PASSENGER FRONT AND BOTH REAR DOORS
LR Latch BLACK/ RED (-) AT BCM MODULE
RR Latch BLACK/ RED (-) AT BCM MODULE
Trunk Trigger BLACK / YELLOW (-) AT BCM MODULE
   ALSO AT TRUNK LAMP
Alarm Disarm BROWN (-) AT BCM MODULE
   ALSO IN DRIVER KICKPANEL TO DOOR
Alarm Arm LIGHT GREEN/ BLACK (-) AT BCM MODULE
Parking Lights RED / YELLOW (+) IN HARNESS IN DRIVERS KICKPANEL
Low Crr Pk Lights RED / YELLOW (-) VEHICLE LIGHT SWITCH
   ALSO BLUE/WHITE OR RED / YELLOW AT BCM
Convenience
Wipers-Lo BLUE / YELLOW (+) AT WIPER CONTROL SWITCH
Wipers-Hi BLUE/RED (+) AT WIPER CONTROL SWITCH
Parking Brake RED / BLUE (-) AT BCM MODULE
   ALSO AT PARKING BRAKE SWITCH
Trnk Release BLUE / YELLOW (REV) AT BCM MODULE
   MUST ISOLATE FROM BCM WITH RELAY
Remote Start
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Accessory 2 BLUE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE / YELLOW (+) IGNITION SWITCH HARNESS
Tachometer GREEN/ YELLOW (AC) AT ECM MODULE
Speed Sense VIOLET (AC) AT BCM MODULE
   ALSO AT RADIO HARNESS ON SOME MODELS
Low Crr. Pk Lights RED / YELLOW (-) VEHICLE LIGHT SWITCH
Brake Lights GREEN / WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn BLUE (-) IN HARNESS AT STEERING COLUMN
Rear Defrost GREEN/ YELLOW
   ALSO BROWN OR RED / BLACK (-) AT BCM MODULE
Modules
WIRE LOCATION
Module 1 BCM - UNDER DRIVER SIDE OF DASH UNDER STEERING COLUMN
Module 2 ECM - UNDER HOOD NEXT TO BATTERY
Module 3 KEYLESS ENTRY RECEIVER - BEHIND GLOVEBOX TO RIGHT SIDE
Doorlocks/Windows
Power Unlock GRAY/RED (-) AT BCM MODULE
   ALSO IN HARNESS IN DRIVER KICKPANEL TO DOOR
PowerLock GRAY/WHITE (-) AT BCM MODULE
LF Window Up RED (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn GREEN (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up RED / WHITE (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn GREEN / WHITE (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up BLUE / YELLOW (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn GREEN/ YELLOW (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up RED / BLACK (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn WHITE/ GREEN (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
Note: Code Systems makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Code Systems disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
