2010 hyundai veracruz remote start
Dbfordtech
Member - Posts: 28
Posted: October 23, 2010 at 10:45 AM / IP Logged
Hello,
I am looking for information, wiring, and tips to install
a remote starter on a 2010 Hyundai Veracruz with Proximity keys.
I have installed plenty of remote start systems in my day, but got out of it about 6 years ago, and I know things have changed!
Any information would be great.
Thanks in advance...
DBFORDTECH.
icearrow6
Copper - Posts: 497
Posted: October 23, 2010 at 12:22 PM / IP Logged
HYUNDAI
MODEL      YEAR(S)
VERACRUZ      2007 -2010
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
PART       COLOR      LOCATION
12 VOLT CONSTANT      RED (+) 40 AMP      @ IGNITION SWITCH, (6-PIN PLUG), PIN 5
STARTER      GREEN (+)      @ IGNITION SWITCH, (6-PIN PLUG), PIN 1
STARTER 2      N/A
IGNITION 1      ORANGE (+)      @ IGNITION SWITCH, (6-PIN PLUG), PIN 6
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      BLUE (+)      @ IGNITION SWITCH, (6-PIN PLUG), PIN 3
ACCESSORY /HEATER BLOWER 2      YELLOW (+)      @ IGNITION SWITCH, (6-PIN PLUG), PIN 4
KEYSENSE      N/A
PARKING LIGHTS ( - )      ORANGE (-)      @ BCM, (26-PIN PLUG), PIN 8, NOTE #2
PARKING LIGHTS ( + )      GREEN(+)(Left) and YELLOW(+)(Right) use both!      @ DASH FUSE BOX, (GRAY, 39-PIN PLUG(D), PINS 11 and 24
POWER LOCK      NOTE #3      @ POWER WINDOW MAIN SWITCH, (23-PIN PLUG), PINS 16 and 14
POWER UNLOCK      NOTE #4      @ POWER WINDOW MAIN SWITCH, (23-PIN PLUG), PINS 17 and 14
DOOR TRIGGER      ORANGE (-)      @ DASH FUSE BOX, (10-PIN PLUG(F), PIN 10
DOMELIGHT SUPERVISION      BROWN (-)      @ DASH FUSE BOX, (10-PIN PLUG(F), PIN 8
TRUNK RELEASE      GREEN/ BLACK (-), without POWER TAILGATE, NOTE #5      @ BCM, (26-PIN PLUG), PIN 22, NOTE #2
SLIDING POWER DOOR      N/A
HORN      PINK or BLUE/BLACK (-)      in DRIVERS KICK PANEL, (BLACK, 18-PIN PLUG), PIN 9
TACH      Any wire NOT ORANGE (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      GREEN to GREEN/ BLACK (+)      @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, (WHITE, 14-PIN PLUG), PIN 12
FACTORY ALARM DISARM      Use UNLOCK wires
ANTI-THEFT      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1      @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE #1: HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass for REMOTE START Part # DLPK-CANBUS MULTI for REMOTE START/DOOR LOCKS NOTE #2: the BCM, (Body Control Module) is located under the DRIVERS DASH. NOTE #3: use both wires, the BROWN / ORANGE gets the (-) and the GRAY/BLACK must be OPEN, TEST these wires while turning the KEY in the DRIVERS DOOR. NOTE #4: use both wires, the PINK gets the (-) and the GRAY/BLACK (-), TEST these wires while turning the KEY in the DRIVERS DOOR. NOTE #5: on Vehicles with POWER TAILGATE, use the ORANGE (-), at the POWER LIFTGATE SWITCH, (5-PIN PLUG), PIN 4
Dbfordtech
Member - Posts: 28
Posted: October 23, 2010 at 12:29 PM / IP Logged
Thank you for the response, but I don't believe this wiring diagram covers the proximity key (or smart key) I found a very similar wiring diagram to this at Bull Dog Security, and it was for Cars without this type of key.
icearrow6
Copper - Posts: 497
Posted: October 23, 2010 at 12:40 PM / IP Logged
          #520231: 2010 HYUNDAI VERACRUZ 4DR SUV WITH 3.8L ENGINE AND INFINITY® AUDIO SYSTEM
Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
Battery          RED          (+)          RADIO HARNESS
Accesory          GREEN/ BLACK          (+)          RADIO HARNESS
Ground          BLACK          (-)          RADIO HARNESS
Illumination          YELLOW          (+)          RADIO HARNESS
Dimmer          BLACK/ ORANGE          (-)          RADIO HARNESS
Power Antenna          GREEN          (+)          RADIO HARNESS
Amp Turn On          GRAY          (+)          RADIO HARNESS
Amp Location          ON LEFT SIDE OF CARGO AREA BEHIND TRIM PANEL
Steering Cntrls          YES
Speed Cntrl          YES
Radio Security          YES
Security
Battery          PINK          (+)          IGNITION SWITCH HARNESS
THIS WIRE IS FUSED AT 40 AMPS, ALSO RED AT IGNITION SWITCH FUSED AT 40 AMPS
Ignition 1          ORANGE          (+)          IGNITION SWITCH HARNESS
Starter 1          GREEN          (+)          IGNITION SWITCH HARNESS
LF Latch          PINK          (-)          IN HARNESS IN DRIVER KICKPANEL
MAY ALSO BE PINK/BLACK
RF Latch          PINK/BLACK          (-)          IN HARNESS IN PASSENGER KICKPANEL
LR Latch          YELLOW/BLACK          (-)          IN HARNESS IN DRIVER KICKPANEL
RR Latch          GRAY/BLACK          (-)          IN HARNESS IN PASSENGER KICKPANEL
Trunk Trigger          WHITE          (-)          IN HARNESS TO GAUGES
ALSO AT LAMP IN CARGO AREA
Hood Trigger          RED / BLACK          (-)          AT BCM MODULE UNDER DRIVER SIDE DASH
Alarm Disarm          PINK          (-)          AT SWITCH IN DRIVER DOOR
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER
Alarm Arm          BROWN / ORANGE          (-)          AT SWITCH IN DRIVER DOOR
Parking Lights          YELLOW          (+)          IN HARNESS IN DRIVER KICKPANEL
Convenience
All Hazrd Lights          WHITE/ ORANGE          (-)          AT VEHICLE HAZARD SWITCH
ALSO AT BCM UNDER DRIVER SIDE DASH
Fuel Dr Release          BLUE/ORAGNE          (+)          AT GAS DOOR RELEASE SWITCH
Remote Start
Ignition 2          BLUE          (+)          IGNITION SWITCH HARNESS
Accessory 1          YELLOW          (+)          IGNITION SWITCH HARNESS
Anti-Theft Type          UNIVERSAL IMMOBILIZER
Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense          PINK          (-)          IGNITION SWITCH HARNESS
Tachometer          WHITE          (AC)          AT ECM MODULE BEHIND PASSENGER HEADLIGHT
Speed Sense          BROWN          (AC)          AT DATA LINK CONNECTOR UNDER DRIVER SIDE DASH
Brake Lights          GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights          BLUE          (+)          AT VEHICLE FUSE/JUNCTION BOX
Horn          BLUE/BLACK          (-)          IN HARNESS AT STEERING COLUMN
MAY BE PINK
Alarm Indicator          GREEN/ ORANGE          (-)          AT BCM MODULE UNDER DRIVER SIDE DASH
Modules
     WIRE          LOCATION
Module 1          ABS MODULE- UNDER HOOD NEAR MASTER CYLINDER
Module 2          ECM- UNDER HOOD BEHIND PASSENGER HEADLIGHT
Module 3          BCM- UNDER DRIVER SIDE DASH
Module 4          DATA LINK CONNECTOR- UNDER DRIVER SIDE DASH, NEAR FOOTWELL LAMP
Doorlocks/Windows
Power Unlock          GRAY/BLACK          (-)          AT SWITCH IN DRIVER DOOR
PowerLock          BROWN / ORANGE          (-)          AT SWITCH IN DRIVER DOOR
LF Window Up          GREEN          (REV)          AT DRIVER WINDOW CONTROL SWITCH
LF Window Dn          WHITE          (REV)          AT DRIVER WINDOW CONTROL SWITCH
RF Window Up          GREEN          (REV)          AT FRONT RIGHT WINDOW CONTROL SWITCH
RF Window Dn          WHITE          (REV)          AT FRONT RIGHT WINDOW CONTROL SWITCH
LR Window Up          ORANGE          (REV)          AT REAR LEFT WINDOW CONTROL SWITCH
LR Window Dn          BLUE          (REV)          AT REAR LEFT WINDOW CONTROL SWITCH
RR Window Up          ORANGE          (REV)          AT REAR RIGHT WINDOW CONTROL SWITCH
RR Window Dn          BLUE          (REV)          AT REAR RIGHT WINDOW CONTROL SWITCH
Sunroof Open          WHITE          (-)          AT SUNROOF CONTROL SWITCH
Sunroof Close          BROWN / BLACK          (-)          AT SUNROOF CONTROL SWITCH
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
