2000 maxima remote start
Platinum - Posts: 7,789
Posted: November 04, 2010 at 12:13 PM / IP Logged
Did you program the Viper to Automatic Transmission?  Menu 3, Menu Item 1, Option 2
Posted: November 04, 2010 at 12:17 PM / IP Logged
Both Bulldog and Audiovox list 2 Starter wires.  BLACK/ Red and BLACK/ Blue
razuuk004
Member - Posts: 23
Posted: November 04, 2010 at 1:12 PM / IP Logged
Yes, I programmed Automatic several times and waited for the 2 chirp conformation. And if there is two starter wires, I cut the Black / Red and hooked up Ignition side and Engine side, If there is something to do with the Black / Blue wire than that may be it although I get a Positive signal on the Black / Red wire with test light during key cranking in ignition switch.
Am i suppose to connect both wires? if so, how do i isolate them?
Posted: November 04, 2010 at 3:36 PM / IP Logged
Seven blinks usually means that you are still in MTS and did not enter "Reservation Mode".  It has been mentioned on this forum before that changing to Automatic Trans can be difficult and can take several tries.
Starter2 not connected will allow the car to crank but a "cold" engine will not start.
AudioVox lists two Ignition wires, two Starter wires and one Accessory wire.  Bulldog Security lists one Ignition wire, two Starter wires and two Accessory wires.  Use your DMM or test light to verify.  Either way, if you power all listed wires, you will need an extra relay becuase the Viper can only directly power 4 outputs.  Have you programmed and used the Flex Relay output, H3/7, yet?
If you find that the Bulldog info is correct and use the Flex relay for ACC2, then the extra 30/40A SPDT relay would be used for the second Starter wire.  Connect as follows:
Relay Pin 85 to Viper Remote start auxiliary output, 5-pin, Violet wire (-) 200mA STARTER OUTPUT.
Relay Pins 86 and 87 to +12v constant fused to 20A
Relay Pin 30 to Maxima BLACK/ Blue Starter2 wire
Relay Pin 87a not used - insulate
razuuk004
Member - Posts: 23
Posted: November 05, 2010 at 5:52 AM / IP Logged
Hey Kreg, I'm going to try the Flex Relay today. By your description above, am i just going to wire up pin 30 and tap it into BLACK/ blue wire of Starter2 without spiting the wire? or do I Split BLACK/ blue wire to Ign. side (87a) and Starter side (30).
Posted: November 05, 2010 at 7:26 AM / IP Logged
I'm not sure I'm understanding.  The "Flex Relay" is part of the Viper ( built in).  H3/2 is its' Pin 87, H3/7 is its' Pin 30 and H3/8 is its' Pin 87a. And, while it can be used as Starter2, the previous post uses an "Extra Relay" for the Starter2 and the Vipers' Flex Relay for ACC2.
If you are referring to the "extra relay"  for the Starter2 circuit detailed in the earlier post, just tap Pin 30 into to BLACK/ Blue wire.  The starter kill is done with the cut BLACK/ Red starter wire.  For the cars' Accessory2 circuit, connect H3/2 to +12v constant, H3/7 to the cars ACC2 and set the Menu 3, Menu Item 8 to Option 2 for ACC2.
razuuk004
Member - Posts: 23
Posted: November 05, 2010 at 11:14 AM / IP Logged
Great! I'll try it today and let you know if it worked. Thanks in advance for your help.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
