2011 Jeep Wrangler Alarm/Remote Start/Stereo Wiring
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 2011 Jeep Wrangler Alarm/Remote Start/Stereo Wiring ( Topic Closed)
Welcome Guest :)
Posted: December 13, 2010 at 4:02 PM / IP Logged
Does anyone know would the wiring for a remote start be the same for a 2011 Jeep Wrangler and a 2010??To be old and wise, you must first be young and dumb.
Posted: December 19, 2010 at 1:00 AM / IP Logged
Item Wire Color Polarity Wire Location
12 Volts red + battery or TIPM
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender.
Second 12 Volts lt. blue/red (10A) + ignition switch, black 5 pin plug, pin 5
Starter yellow/gray (not for remote start) + starter or TIPM, blue plug, pin 8
Second Starter PURPLE / brown - 180 ohms ignition switch, black 5 pin plug, pin 2
If interface module is not available, see Tech Doc 1084 for wiring information.
Ignition pink/white + ignition switch, black 5 pin plug, pin 3
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter - 610 ohms
Second Accessory N/A
Third Accessory N/A
Keysense same as second starter -8.5K ohms
Data Bus N/A
Can Bus High WHITE/ black (CAN C BUS) data SKREEM, black 8 pin plug, pin 6
The SKREEM (Sentry Key Remote Entry Module) is around the ignition key switch. The CAN INT BUS High wire is WHITE/ gray in the driver kick, door harness or the TIPM, black plug (C7), pin 26. The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender.
Can Bus Low WHITE/ lt. blue (CAN C BUS) data SKREEM, black 8 pin plug, pin 7
The SKREEM (Sentry Key Remote Entry Module) is around the ignition key switch. The CAN INT BUS Low wire is WHITE/ orange in the driver kick, door harness or the TIPM, black plug (C7), pin 27. The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender.
Can Bus Sw N/A
Power Lock PURPLE / dk. green - 330 ohms driver kick or TIPM, black plug (C7), pin 2
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender. On vehicles with express windows, have to go into the passenger door and use PURPLE / lt. green at the PDM (Passenger Door Module), blue plug, pin 4.
Power Unlock same as power lock - 100 ohms
Lock Motor tan/white 5 wire driver kick or TIPM, gray plug, pin 8
Driver Unlock Motor tan/lt. green 5 wire driver kick or TIPM, gray plug, pin 3
Passenger Unlock Motor tan/orange 5 wire driver kick or TIPM, brown plug, pin 18
Parking Lights (-) (LIN BUS)
Parking Lights (+) WHITE/ purple + driver kick or TIPM, brown plug, pin 36
Hazards WHITE/ dk. blue - hazard switch or TIPM, black plug (C7), pin 9
Turn Signal (Left) WHITE/ lt. green (F), WHITE/ dk. green (R) + TIPM, lt. gray plug, pin 9 (F); black plug (C7), pin 49 (R)
Turn Signal (Right) WHITE/ tan (F), WHITE/ orange (R) + TIPM, lt. gray plug, pin 7 (F); black plug (C7), pin 50 (R)
Headlight WHITE/ dk. blue (L), WHITE/ tan (R) + headlights or TIPM, green plug, pins 3 and 11
AutoLights N/A
Reverse Light WHITE/ lt. green + driver kick or TIPM, brown plug, pin 15
Left Front Door Trigger purple - driver kick or TIPM, black plug (C7), pin 11
Right Front Door Trigger PURPLE / white - driver kick or TIPM, black plug (C7), pin 12
Left Rear Door Trigger PURPLE / gray - driver kick or TIPM, black plug (C7), pin 16
Right Rear Door Trigger purple / YELLOW - driver kick or TIPM, black plug (C7), pin 14
Dome Supervision yellow/white + driver kick or instrument cluster, black plug, pin 7
Trunk/Hatch Pin PURPLE / orange - driver kick or TIPM, black plug (C7), pin 15
Rear Glass Pin purple / YELLOW - driver kick or TIPM, black plug (C7), pin 17
Hood Pin PURPLE / lt. blue - hood switch or TIPM, lt. gray plug, pin 3
Trunk/Hatch Release ORANGE / purple (glass) - driver kick or TIPM, black plug (C7), pin 5
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender. Meter this wire while opening the liftgate glass from the handle on the rear of the vehicle.
Trunk Release Motor ORANGE / gray (glass) + driver kick or TIPM, black plug (C7), pin 42
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock Sentry Key, ignition, and keysense
Trunk Alarm Shunt N/A
Tachometer NOT BROWN / white ac any fuel injector
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal black (in), yellow/dk. blue (out) - N.O.
clutch pedal switch
Fuel Pump dk. blue/orange + driver kick or TIPM, brown plug, pin 10
Rear Defroster dk. blue/white + latched driver kick or TIPM, brown plug, pin 32
Mirror Defroster dk. blue/lt. blue + latched driver kick or TIPM, brown plug, pin 19
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender. On vehicles with express windows, have to go into each door. The driver heated mirror is dk. blue/gray at the DDM (Driver Door Module), black plug, pin 4. The passenger heated mirror is lt. blue/white at the PDM (Passenger Door Module), black plug, pin 4.
Left Front Heated Seat lt. GREEN/ brown 5 wire Heated Seats Module, pin D
The Heated Seats Module is under the passenger seat.
Right Front Heated Seat lt. GREEN/ purple 5 wire Heated Seats Module, pin K
Speed Sense dk. GREEN/ brown ac PCM, plug towards rear, pin 32
The PCM (Powertrain Control Module) is in the engine compartment, on the passenger fender.
Brake Wire WHITE/ dk. green + driver kick or TIPM, black plug (C7), pin 10
Parking Brake dk. GREEN / WHITE - parking brake switch or instrument cluster, brown plug, pin 7
Horn Trigger dk. GREEN/ purple - horn switch or instrument cluster, black plug, pin 10
Wipers BROWN / white (L), BROWN / orange (H) + wiper motor or TIPM, brown plug, pins 12 and 11
Left Front Window (Up/Down) ORANGE / lt. green - ORANGE / white A driver window switch in door
On vehicles with express windows, use ORANGE / lt. blue - ORANGE / dk. blue at the window motor in the door. Use the 529T only on these.
Right Front Window (Up/Down) ORANGE / tan - ORANGE / gray A driver kick, door harness
On vehicles with express windows, use dk. blue/orange - lt. GREEN/ orange at the window motor in the door. Use the 529T only on these.
Left Rear Window (Up/Down) ORANGE / white - ORANGE / gray A driver kick, door harness
Right Rear Window (Up/Down) ORANGE / lt. blue - ORANGE / dk. blue A driver kick, door harness
Sun Roof (Open/Close) org/tan - org/lt. blu (functions with ign on only) - sunroof switch
Sun Roof (Limit/Close) N/A
Memory Seat 1 PURPLE / brown - resistor DDM, blue plug, pin 6
The DDM (Driver Door Module) is in the driver door.
Memory Seat 2 same as memory seat 1 - resistor
Memory Seat 3 N/A
Radio 12V red or yellow/red + radio, gray 22 pin plug, pin 1
Radio Ground BLACK/ white - radio, gray 22 pin plug, pin 12
Radio Ignition (CAN BUS)
Radio Illumination (CAN BUS)
Factory Amp Turn-on (CAN BUS)
Power Antenna gray/orange + radio, gray 22 pin plug, pin 7
Left Front Speaker (+/-) gray/purple - gray / YELLOW +,- radio, gray 22 pin plug, pins 21 and 22
If equipped, the amplifier is in the passenger side rear quarter panel. On vehicles with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier, 16 pin plug, pins 8 and 16. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, 22 pin plug, pins 20 and 9.
Right Front Speaker (+/-) dk. GREEN/ purple - dk. GREEN/ YELLOW +,- radio, gray 22 pin plug, pins 19 and 20
If equipped, the amplifier is in the passenger side rear quarter panel. On vehicles with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier, 16 pin plug, pins 7 and 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, 22 pin plug, pins 19 and 8.
Left Rear Speaker (+/-) gray/lt. green - gray/dk. green +,- radio, gray 22 pin plug, pins 8 and 9
If equipped, the amplifier is in the passenger side rear quarter panel. On vehicles with amplifier, the speaker and tweeter wires are gray/lt. green - gray/dk. green at the amplifier, 16 pin plug, pins 13 and 5.
Right Rear Speaker (+/-) dk. GREEN/ lt. green - dk. GREEN/ gray +,- radio, gray 22 pin plug, pins 10 and 11
If equipped, the amplifier is in the passenger side rear quarter panel. On vehicles with amplifier, the speaker and tweeter wires are dk. GREEN/ lt. green - dk. GREEN/ gray at the amplifier, 16 pin plug, pins 4 and 12.
Center Channel (+/-) N/A
Subwoofer (+/-) gry/brn - dk. grn/brn(1), gry/wht - dk. grn/wht(2) +,- amplifier, 16 pin plug, pins 14 and 6 (1), 3 and 11 (2)
Aux. Audio Input Left (+/-) gray/lt. blue - dk. GREEN/ purple (common) +,- auxiliary AV port, 8 pin plug, pins 1 and 3
Aux. Audio Input Right (+/-) gray/dk. blue - dk. GREEN/ purple (common) +,- auxiliary AV port, 8 pin plug, pins 2 and 3
RSE Video (+/-) gry/brn - gry/yel (1), gry/lt. blu - gry/yel (2) +,- radio, white 22 pin plug, pins 6, 7 (1); 9, 10 (2)
RSE Audio Left (+/-) see notes
Audio 1: dk. GREEN/ tan (left), dk. GREEN / WHITE (right), gray/purple (common) at radio, white 22 pin plug, pins 18, 20, and 19. Audio 2: dk. GREEN/ lt. blue (left), dk. GREEN/ dk. blue (right), gray/orange (common) at radio, white 22 pin plug, pins 21, 22, and 12. Audio 3: dk. GREEN/ purple (left), dk. GREEN/ YELLOW (right), gray/lt. blue (common) at radio, white 22 pin plug, pins 13, 14, and 1.
RSE Audio Right (+/-) see RSE audio left
Satellite Radio 12 Volts N/A
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit double DIN 6.35 center of dash
Left Front Speaker 6.5 3.5 left front door
Left Front Tweeter 3.5 2.75 left front dash
Right Front Speaker 6.5 3.5 right front door
Right Front Tweeter 3.5 2.75 right front dash
Left Rear Speaker 6.5 3.5 left rear door
Left Rear Tweeter left rear door
Right Rear Speaker 6.5 3.5 right rear door
Right Rear Tweeter right rear door
Center Channel N/A
Subwoofer 8 5.25 passenger side rear quarter panel
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio)
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
CANBUS OEM Security System
Type:
Firmware:
VIN Code:
Part #'s:
HS (High Speed)
Directed 3903T, Viper 3903V, Clifford 330X3 (UK)
Notes:
Interface Modules
SKU Module Description Upgradeable Keys Required for Programming Keys Required for Operation
© 2007 Directed Electronics. All Rights Reserved.
DirectWire and its vehicle information are for the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
Gary Sather
Search the12volt.com |
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
