charging extra for standard cars?
cloppy
Member - Posts: 11
Posted: January 04, 2011 at 9:43 PM / IP Logged
Hello
This question for is for all you intallers out there.
Do you charge extra for cars that arte stick when installing a remote starter?
Thank you
tedmond
Gold - Posts: 4,610
Posted: January 04, 2011 at 10:10 PM / IP Logged
i assume youre talkin about remote start?
i upcharge an extra 20 bucks for manual. Its only an extra 2 wires to run (door trigger, parking brake)
Ted
Compustar Expert
lspker
Silver - Posts: 503
Posted: January 04, 2011 at 10:42 PM / IP Logged
If I can get away with it.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 04, 2011 at 11:49 PM / IP Logged
you will get away with it.... AND you should charge more than twenty dollars.
You are selling them a safety feature, it's worth more than twenty bucks my friend. get 50.00
Platinum - Posts: 13,667
Posted: January 05, 2011 at 6:09 AM / IP Logged
DId Tedmond forget about the clutch?
tedmond
Gold - Posts: 4,610
Posted: January 05, 2011 at 7:59 AM / IP Logged
yeah i did, but i concider the start wire as my clutch bypass.
its 120 for any alarm or RS to be installed, and 150 for alarm/rs setups. that is "cheap" compared to others.
what do you guys charge for basic install exluding bypass module(s)?
Ted
Compustar Expert
Thack79
Silver - Posts: 526
Posted: January 05, 2011 at 9:12 AM / IP Logged
i charge the EXACT same (on average).
chev104275
Gold - Posts: 1,427
Posted: January 05, 2011 at 7:15 PM / IP Logged
We get 499.99.   399.99 during the holidays.   But it doesn't matter on what the install is.   Sliding doors. Trunk release.   Rear defrost.   Power hatch control.   If the vehicle has it factory I have to make it work with the aftermarket remote
tedmond
Gold - Posts: 4,610
Posted: January 05, 2011 at 10:26 PM / IP Logged
i assume 399.99 is install + a unit right?
what units do you install chev?
Ted
Compustar Expert
chev104275
Gold - Posts: 1,427
Posted: January 06, 2011 at 5:41 AM / IP Logged
Yes it includes everything kit and install and bypass if required.   I do viper , avital, ford code alarm and Kia code alarm
