2009 Nissan Versa, No Smart Key, Alarm/Remote Start Wiring
hondaoskar
Posted: January 15, 2011 at 11:08 PM / IP Logged
from canada , keyless , someone have wiring diagram ? need a transponder bypass ? Thansk a lot !
Oskar
Moderator - Posts: 12,488
Posted: January 16, 2011 at 9:26 AM / IP Logged
Use iDatalink ALCA for bypass and follow instructions for it as per installation manual. The wiring for the car is as follows:
emote Start
Item     Wire Color     Polarity     Wire Location
12 Volts     Blue [40A]     +     Ignition Switch, White 6 Pin Plug, Pin 3
Second 12 Volts
Starter     White     +     Ignition Switch, White 6 Pin Plug, Pin 2
Second Starter
Ignition     Red     +     Ignition Switch, White 6 Pin Plug, Pin 1
Second Ignition
Third Ignition
Accessory     Yellow     +     Ignition Switch, White 6 Pin Plug, Pin 4
Second Accessory     Brown     +     Ignition Switch, White 6 Pin Plug, Pin 5
You need to power up the second Acc (brown) only if you do the rear defogger option.
Third Accessory
Keysense     RED / White     +     At Ignition Switch
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock     Gray     -     Harness From Driver's Door In A 16 Pin Conn.
Power Unlock     Purple To Blue     -     Harness From Driver's Door In A 16 Pin Conn.
Lock Motor
Driver Unlock Motor     Green     Reverse     Harness From Driver's Door In A 17 Pin Conn.
Parking Lights (-)
Parking Lights (+)     Purple     +     At Dimmer Switch
Also can use a Gray (+) in driver's kick in running board harness
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight
AutoLights
Reverse Light     Yellow     +     Passenger Kick Panel In A 16 Pins White Conn.
Left Front Door Trigger     Brown     -     At SECM Behind Glove Box, In A 15 Pin Con. Pin 7
Right Front Door Trigger     Lt.Blue     -     At SECM Behind Glove Box, In A 40 Pin Con. Pin 12
Left Rear Door Trigger     Orange     -     At SECM Behind Glove Box, In A 15 Pin Con. Pin 8
Right Rear Door Trigger     Gray     -     At SECM Behind Glove Box, In A 40 Pin Con. Pin 13
Dome Supervision
Trunk/Hatch Pin     Pink To Red     -     At SECM Behind Glove Box, In A 15 Pin Con. Pin 3
pink to yellow (sedan) passenger kick or BCM, white 15 pin plug, pin 2 , pink to red (hatchback) passenger kick or BCM, white 15 pin plug, pin 3
Rear Glass Pin
Hood Pin
Trunk/Hatch Release     Blue To Purple Or Lt. Green     -     Passenger Kick Or BCM, White 40 Pin Plug, Pin 30
Trunk Release Motor     Blue To Purple Or Lt. Green     -     Passenger Kick Or BCM, White 40 Pin Plug, Pin 30
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm     Orange Or Brown     -     Harness From Driver's Door In A 16 Pin Conn.
Factory Alarm Disarm     Yellow     -     Harness From Driver's Door In A 16 Pin Conn.
Disarm No Unlock
Trunk Alarm Shunt     White (Sedan Only)     -     Passenger Kick Or BCM, White 15 Pin Plug, Pin 1
Tachometer     Green     1 Cyl     At Ignition Coil
Also can use a Blue at The ECM (Engine Control Module) is in the engine compartment, on the driver strut tower
Wait to Start
Neutral Safety
Clutch Pedal     Brown     +     At Clutch Switch
This is not a Starter wire, it is just a positive pulse that will bypass the clutch, use a relay with a pulse set for Starter.
Fuel Pump     White     +     Passenger Kick Panel In A 16 Pins White Conn.
Rear Defroster     White     Neg 1 Sec.     At SECM Behind Glove Box, In A 40 Pin Con. Pin 9
You have to send a 1 second pulse to activate the rear defogger and the indicator will turn On.(read comment #3).
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense     Lt. Blue     8 Pulse     Radio, White 20 Pin Plug, Pin 18
May not be present on vehicles with base level audio systems.
Brake Wire     Red     +     At Brake Switch
Parking Brake     Lt.Blue     -     Behind Instrument Cluster Pin 31
Horn Trigger     Pink     -     Main Harness Or Horn Switch, Gray 8 Pin Plug, Pin
Posted: January 16, 2011 at 9:27 AM / IP Logged
BTW, make sure you install the relay under the hood fuse panel to ensure that the vehicle is safe to start.
hondaoskar
Posted: January 17, 2011 at 8:54 PM / IP Logged
thnaks i will try soon
Oskar
hondaoskar
Posted: January 17, 2011 at 8:57 PM / IP Logged
can i use a universal bypass with a chip inside ?
Oskar
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
