2011 Chevy Cruze Remote Start Wiring
factionaudio
Posted: February 17, 2011 at 10:12 AM / IP Logged
Anyone have a diagram for Cruze? I have the bypass diagrams but cant seem to find the cars wiring? I know its not rocket science to test for them I just dont feel like it.
ExtremeProAudio
Member - Posts: 45
Posted: February 22, 2011 at 11:52 PM / IP Logged
12volts      RED / dk. green (100A)      +      dash fuse box, pin 48
Notes: The BCM (Body Control Module) is in the front passenger side of the center console.
Starter      yellow (for starter kill only)      +      starter or underhood fuse box, black 50 pin plug (X3), pin 5
Second Starter      WHITE/ purple (resistor code)       +9.6K ohms      ignition switch or BCM, lt. green 25 pin plug, pin 15
If interface module is not available, see Tech Doc 1605.
Ignition      PURPLE / black      +      ignition switch or BCM, lt. green 25 pin plug, pin 6
Second Ignition      N/A
Third Ignition      N/A
Accessory      purple / YELLOW      +      ignition switch or BCM, lt. green 25 pin plug, pin 5
Second Accessory      same as second starter      +6.3K ohms
Keysense      same as second starter
Power Lock      BROWN / yellow      -      door lock switch or BCM, lt. blue 27 pin plug, pin 19
Power Unlock      BROWN / white      -      door lock switch or BCM, lt. blue 27 pin plug, pin 15
Lock Motor      BROWN / yellow      5 wire      BCM, pink 27 pin plug, pin 4
Unlock Motor      gray      5 wire      BCM, pink 27 pin plug, pin 1
Parking Lights+      pur/gray (L), gray/brn (R), dk. grn/yel (license)      +      BCM, black 26 pin plug, pins 6, 5, and 13
Parking Lights-      dk. GREEN/ gray      -      headlight switch or BCM, white 26 pin plug, pin 22
Hazards      dk. GREEN / WHITE      -      hazard switch or BCM, lt. blue 27 pin plug, pin 26
Turn Signal(L)      dk. blue/white (F), dk. blue/white (R)      +      BCM, brown 26 pin plug, pins 2 and 1
Turn Signal(R)      dk. GREEN/ purple (F), dk. blue/purple (R)      +      BCM, black 26 pin plug, pins 3 and 4
Reverse Light      dk. GREEN / WHITE      +      BCM, gray 26 pin plug, pin 3
Door Trigger      gray      -      driver window switch, black 8 pin plug, pin 6 (express down window)
Notes: On vehicles with express up and down power windows, this wire is at the driver window motor, black 7 pin plug, pin 6.
Dome Supervision      gray      +      BCM, gray 26 pin plug, pin 1
Trunk/Hatch Pin      PURPLE / gray      -      BCM, pink 27 pin plug, pin 5
Hood Pin      BROWN / dk. green      -      BCM, pink 27 pin plug, pin 6 or black 26 pin plug, pin 24
Trunk/Hatch Release      yellow/dk. blue (rear handle switch)      -      BCM, pink 27 pin plug, pin 15
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      factory remote only
Disarm No Unlock      Passkey and ignition
Tachometer      BROWN / pur, yellow/wht, BROWN / pur, or BROWN / yel      ac      any fuel injector, black 2 pin plug, pin 2
Wait to start      N/A
Brake Wire      PURPLE / white      +      BCM, black 26 pin plug, pin 11
Parking Brake      dk. blue/purple      -      parking brake switch or BCM, gray 26 pin plug, pin 15
Horn Trigger      dk. GREEN / WHITE      -      horn switch or BCM, lt. green 25 pin plug, pin 18
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
ExtremeProAudio
Member - Posts: 45
Posted: February 22, 2011 at 11:56 PM / IP Logged
Although, you will not have to make most of those connections. If you are using the XK09, just follow those wiring instructions that came with.
