1996 Chevy tahoe 4x4
Planning a big G5 alarm and convenience sytem to go in next month. I will have the main alarm, intellistart and smart windows as well as a host of other options. Here are some questions.
1. Since the modules have supply have a seperate 12v+ input feeds to run there outputs is it not feasable for each unit's high current power input to to tap and solder into it equivalant power supply wire into the vehicle harnesss since there are not increasing the load on existing wires? Merely just switching it on a different path. For example intellistart 2 power feeds will tap into the two ignition switch feeds-parking lights flasher feed into the headlight switch main feed and so forth. Trying to avoid installing a battery fed fuse panel for for it all right now.
2. has anybody ever been able to extend the data link cable between the modules 2-3x longer then original without ill effects so the modules can be further seperated by distance and still communicate?
3. Will the smartwinwindows G4 comlink with the G5 units? Need a confirmation on this. They should but I have talked to installers who cannot give a definite answer cause they find cliffords to complicated to even want to install.
4. If the rpm-based door autolock function is enabled will it only lock after the initial start and drive-off or every time that it detect a door has been opened and closed?
5. I have the 520t backup-battery so will it be strong enough to run the three controller constant 12v cpu feeds or if I have to use the battery on just the main cpu how will it deal with with the comlink loss off start and windows modules? Does it actually check the data path for existance of the modules each time there is data to be move from one to the other? Or if vehicle power supply is severed will the main cpu logicly lock-up and cease to function cortectly it own functions becuase two mudules dropped offline?
6. I have a medalion siren from a G4 bullet. Can that be used on the optional siren wires from the main cpu in addition to the smart siren or do I have to have the the newer 518c neo siren? Anyone have a manual on the neo unit? Was going to use the second siren inside the vehicle.
7. With this and stereo equipment w/nav, sat-radio and bluetooth models added on and some other electrical stuff to go in has anybody some creative ideas to find room for all this stuff in a tahoe. The backseat and pasenger front unders will already be occupied with an dual down- firing sub box and amp respectively. The glove box and overhaead console will also be used for sensorsor modules as well. Or is it benificial to put the sub box in the cargo area. How about a creative electrical grid and electronics base in the cargo area covered by a newly formed supprorted floor with ventalation. I don't mind loosing a few inches of vertical height back there or is that pushing it to far.
Thanks for any thoughts or ideas.
