Don't worry, there are no dumb questions on this site. Most of us are trying to increase our knowledge as well
As for your questions...
1) Words still undecided on running amps and not using all the channels. I have personally done this with Kenwood amps before and did not experience a problem. What I would suggest if you run only 1 speaker, is only hook up 1 RCA cable (that is to say if you only run the Left channel of the amp, only run 1 RCA cable using the left input). I said left because most mono setups default to the left channel. By not hooking up the right RCA, you wont have that signal going to the amp and not being used. Just a thought
2) The knob you are referring to is more connonly called the "Gain control". This is an adjustment that allows you to match the amplifier's input voltage to the headunit's RCA pre-out output voltage. By increasing or decreasing the gains, you adjust how "sensitive" the amp's input signal is. Common rule of thumb if you don't know the exact setting to use (or just want to tweak the system) is to turn the gains all the way down, turn the headunit about 3/4 of the way up in volume, then slowly turn the gains up until you start to hear distortion. At that point, back the gains down a little bit (back to a clear/undistorted signal) and you should be at the right setting. One thing to remember about adjusting gains, The higher the number, and usually turning the knob counter-clockwise, is called turning the gains down. The lower the number, and usually turning the knob clockwise, is called turning the gains up. In short, 4volts is a lower sensitivity level than 0.2volts. I believe most headunits have 2 or 3volt RCA pre-outs. But like I said, start low first, then raise the gains. And yes, if you turn the gains down you will be decreasing the amout of wattage that the amp will be outputting (I'm not sure of the exact math behind it though). That's why you start with the gains turned all the way down first (especially if the wattage of the speakers is in question!)
3) You are correct on DVC inputs. I just got into them myself, but all the ones I've seen have inputs on opposite sides of the speaker. Your speaker is a Single Voice Coil. Many SVC speakers (and even some subs) have the type of configuration that you mentioned (2 +'s and 2 -'s, but they are connected together). This is for ease of installation/mounting and different wiring configurations (parallel, series, parallel/series, etc).
4) Based on what you've described, I would suggest upgrading to either a single 4ohm 200-300watt SVC 10" sub ran bridged, or two 4ohm 200watt SVC 10" subs ran in stereo if you can fit both of them. There are still more options that you could do using 2, 4, or 8ohm subs, but unless you're really interested in them I'll stick with the above configurations. I wouldn't recommend DVC's yet unless you have the $'s to fork out, since they can be expensive, and the wiring gets even more complicated! But if you went with one DVC 10" sub, it would need to be 2ohms, wired in series and bridged for a 4ohm total load like this...
If you're curious on more wiring configurations, here's a
link to one of many wiring wizards out there.
5) Actually, the preferred installation method
is to run the power wire straight from the battery (fused within 18 inches of the battery). The amp remote can be hooked up to the power antenna wire (if you tested and get signal with both the radio and CD player on). Are you still using the factory headunit? If not, what are you using and I can try to tell you what the remote line is (usually straight blue for remote and blue/white for power antenna on aftermarket headunits). If you are still running the factory headunit, I believe your power antenna wire is BLACK/ red. You could also hook it up to your ignition switch if you wanted too instead. You could also install a toggle switch on the remote line to manually turn it on/off.
Hope that helped. I'm finally off work and getting ready to catch some ZZZZ's!
Again, don't be afraid to ask any questions here
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
