need a relay guru
drgixxer
Posted: April 02, 2011 at 12:48 AM / IP Logged
I want to add a wireless system to my 5th wheel toy-hauler to control the slides, jacks and awning.
I am drawing a blank on how to wire this system up because the switches that are in there are already 5 wire resting neutral.
How do I 5 wire a 5 wire neutral system?
the12volt
Administrator - Posts: 3,955
Posted: April 02, 2011 at 1:15 AM / IP Logged
If both motor legs are normally open, have a peek at this: https://www.the12volt.com/relays/relaydiagram2.html
need a relay guru -- posted image. the12volt • Support the12volt.com
drgixxer
Posted: April 02, 2011 at 1:23 AM / IP Logged
I think that might just work.
hotwaterwizard
Silver - Posts: 1,350
Posted: April 06, 2011 at 12:58 AM / IP Logged
I thought he had a 5 wire system????
https://www.the12volt.com/relays/relaydiagram3.html
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
the12volt
Posted: April 06, 2011 at 1:17 AM / IP Logged
Read his description again. The motor legs are normally open.
hotwaterwizard
Posted: April 07, 2011 at 12:53 AM / IP Logged
A wiring diagram of the existing circuit would help. Some people call the ground leg a neutral.
Stockton California
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
