03 Mini Cooper S Alarm/Remote Start/Stereo Wiring
redlinecustoms
Member - Posts: 34
Posted: April 07, 2011 at 9:54 PM / IP Logged
Ok, I have searched and the best I have found is some reference about the wiring schematic. Is the vehicle wiring for the 03 mini cooper the same as an 03 BMW 3 series? Installing a remote start and would like at least some guidence so I dont have to hunt down and test ever wire.
Jack
Posted: April 08, 2011 at 4:49 AM / IP Logged
Yes. Use a 556UW with the Valet key and treat the Acc (Violet) as a second ignition. Doors triggers and locks are in the body control module.
t&t tech
Platinum - Posts: 2,608
Posted: April 08, 2011 at 6:44 AM / IP Logged
Still test every wire before you connect.
commit your way to jehovah and he will act in your behalf. psalms 37:5
Platinum - Posts: 7,786
Posted: April 08, 2011 at 7:06 AM / IP Logged
Here is 2003 Mini Cooper s info from Audiovox :
Audio/Mobile Video
 WIRE                    COLOR    POLARITY              LOCATION
 Battery                  RED / BROWN    (+)            RADIO HARNESS
 Accesory              VIOLET/BLUE    (+)            RADIO HARNESS
 Ground                 BROWN              (-)            RADIO HARNESS
 Illumination         GRAY/RED         (+)            RADIO HARNESS
 Power Antenna   WHITE                (+)            RADIO HARNESS
 LF Speaker (+)   YELLOW/RED
   THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
 LF Speaker (-)   YELLOW/BROWN
 RF Speaker (+)   BROWN / BLACK
   THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
 RF Speaker (-)     BLUE/BROWN
 LR Speaker (+)    YELLOW/BLACK
 LR Speaker (-)     YELLOW/GRAY
 RR Speaker (+)    BLUE/VIOLET
 RR Speaker (-)     BLUE/GRAY
 Steering Cntrls  NO
 Speed Cntrl      OPTIONAL
 Radio Security   YES
 Security
 Battery                        RED                                                      (+)                IGNITION SWITCH HARNESS
 Ignition 1                   GREEN                                                 (+)                IGNITION SWITCH HARNESS
 Starter 1                    BLACK/ BLUE                                       (+)                IGNITION SWITCH HARNESS
 All Door Trigger       BROWN / GRAY W / YELLOW DOTS   (-)  DR. KICK PANEL
   YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS.
 LF Latch                    BROWN / GRAY / YELLOW DOTS       (-)                  IN HARNESS IN DRIVERS KICKPANEL
 RF Latch                    BROWN / GRAY / YELLOW DOTS       (-)                 IN HARNESS IN PASSENGER KICKPANEL
 Trunk Trigger            GRAY/BROWN                                    (-)                 UNDER PASS. SIDE ROCKER PANEL
 Hood Trigger            GREEN/ VIOLET                                   (-)                PIN SWITCH UNDER HOOD
   OR VIOLET/GREEN AT THE BLACK PLUG AT THE BODY CONTROL MODULE IN THE PASSENGERS KICK PANEL
 Parking Lights           BLACK                                                  (-)                TOP OF THE STEERING COLUMN
   OR AT BLUE PLUG AT THE BODY CONTROL MODULE IN THE PASSENGERS KICK PANEL
  Remote Start
 Ignition 2                         VIOLET/BLACK           (+)                  IGNITION SWITCH HARNESS
 Ignition 3                         GREEN/ BLUE             (+)                  IGNITION SWITCH HARNESS
 Anti-Theft Type  TRANSPONDER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Tachometer                    BLACK / YELLOW        (AC)                 @ COIL ON TOP OF THE ENGINE
   YOU CAN ALSO USE A BLK/BLU YOU CAN ALSO USE AN INJECTOR. THEY ARE EASY TO ACCESS. THE COLORS ARE BRN/YEL, BRN/GRN, BRN/WHT, AND BRN/VIO
 Speed Sense                  BROWN                       (AC)                AT ABS CONTROL MODULE UNDER HOOD BETWEEN RIGHT STRUT TOWER AND FIREWALL                    Parking Lights                 BLACK                           (-)                  TOP OF THE STEERING COLUMN
 Brake Lights                    BROWN / GRAY             (AC)                 @ THE BRAKE LIGHT SWITCH ABOVE BRAKE PEDAL
   YOU MUST TEST WITH IGNITION ON
 Reverse Lights                BLUE / YELLOW             (+)                 IN HARNESS IN DRIVER KICKPANEL
 Modules LOCATION
 Module 1  BCM - BODY CONTROL MODULE IS LOCATED HIGH IN THE DRIVERS KICK PANEL
 Doorlocks/Windows
 Power Unlock                       WHITE/ BLACK OR (WHITE/ GRAY)  (-)       DRIVERS DOOR HARNESS
   THESE WIRES STOP WORKING ON IGNITION, IF YOU ARE ADDING REMOTE START YOU WILL NEED TO MAKE CONNECTIONS TO THE DOOR LOCK SWITCH IN THE CENTER CONSOLE. REMOVE 4 SCREWS ON HOLDING THE GLOVE BOX IN. ACCESS WIRE FROM THAT SIDE. BOTH LOCK AND UNLOCK WIR
 PowerLock                              BLUE/RED                                          (-)         DRIVERS DOOR HARNESS
   FOLLOW SAME AS UNLOCK
 Driver Mtr Unlock                    WHITE                                                (REV)      AT MOTOR IN DOOR
 Driver Mtr Lock                        WHITE                                                (REV)      BLACK PLUG AT BCM IN PASSENGERS KICK PANEL
 Pas Mtr Unlock                       BLUE                                                  (REV)      BLACK PLUG AT BCM IN PASSENGERS KICK PANEL
 Pas Mtr Lock                           BLUE                                                  (REV)       AT MOTOR IN DOOR
Posted: April 08, 2011 at 7:33 AM / IP Logged
The bulldog info has some mistakes.
I think they might have the lock and unlock wire colours the the wrong way round, TEST.
Extend the lock pulse timing for comfort (total) close.
Don't use the brake light feed they mentioned, use BLACK/ blue or BLACK/ green in a floor loom, the BROWN / grey is data only/variable voltage.
Tach wire is probably black pin 9 on the OBD ll/data socket.
Hatch trigger wire might be WHITE/ brown*.
Hatch release, if fitted grey/green, pos, 5 amp fuse to relay.
*If this vehicle follows BMW wiring exactly, you will need to diode the 12+ supply probably RED / yellow at the hatch light, 1N4004 in line, band towards light bulb.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
